BIKELAND > FORUMS > DRAGBIKE ZONE.com > Thread: Head/base gasket compressed thickness NEW TOPIC NEW POLL POST REPLY
Mikkel
posted February 01, 2009 08:46 AM
I have a Cometic C8641 gasket for my 1270, is says .030 on the back of the package, i assume that is compressed thickness? What is the compressed thickness of the stock base gasket / block shim? If i leave out the base gasket do i then need to use any kind of sealer instead?
posted February 01, 2009 10:13 AM
if you leave it out make sure you measure squish. use what ever you use on the cases to seal the block to the cases
posted February 01, 2009 10:19 AM
That would be the compressed thickness. I recollect the stocker at .010". If you do not use the base gasket use some Three Bond 1211 VERY sparingly, same as recommended on the cases.
Mikkel
posted February 01, 2009 11:47 AM
Thanks Scott and Doug!
0.21264004707336 seconds processing time
