BIKELAND > FORUMS > DRAGBIKE ZONE.com > Thread: tool question??? NEW TOPIC NEW POLL POST REPLY
posted January 19, 2009 06:46 AM
tool question???
I am looking for an air or electric driven 1/4 or 3/8" drive which will fit into kinda tight places.
Preferably 1/4" drive.
Specifically to remove cam cover, spark plugs, oil pan.
The oil pan is particularly a PITA with its 76(seems like) lil bolts/cap screws
Any suggestions out there?
ninja12
posted January 19, 2009 07:17 AM
!/4 air rachet, This is what I have. Works great.
http://www.harborfreight.com/cpi/ctaf/displayitem.taf?Itemnumber=34900
Karl , maybe you can kill one with your science project, but it's lasted a couple years for me.
more options.
http://search.harborfreight.com/cpisearch/web/search.do?keyword=air+rachet
Johnnycheese
posted January 19, 2009 02:37 PM
http://www.arizonatools.com/tools/cordless-tools/detail/IRR140/
posted January 19, 2009 02:48 PM
DItto
NOX
PMRA / TMRC Super Street 4022
posted January 19, 2009 05:30 PM
If I have the motor on a stand, I use a cordless drill on a low torque setting......., makes less noise.........
42 Wins
21 Runner-ups
Sponsored by:
Scorpion Helmets
Galfer Braking
AMSOIL
Steve's Speed Shop
Kawasaki Sports Center
Mickey Thompson Tires
Catalyst Racing Composites
Conway Cycle
Syed Leathers
tcchin
posted January 19, 2009 06:04 PM
Can you replace the fasteners with socket-head cap screws and use a T-handle to spin them out? As for the plugs, once they're loose, you should be able to spin them out by hand. Why the need to use power-assisted tools? I'm not a very big fan of using power tools on aluminum threads.
ninja12
posted January 19, 2009 08:32 PM
I like that, no air line in the way!
How is the battery life?
Enough power for clutch springs?
If only I had the money for more tools.
ninja12
posted January 19, 2009 08:39 PM
posted January 19, 2009 10:44 PM
PERFECT! Thanks JC!
Thanks to other folk for responses; the air ratchet would do it but make a buncha noise and have the hose to trip over.
What i need is the ability to get into tight spaces, no room for a T handle.
Yep, plugs, oil pan cap screws(Koenig pan) or bolts (OEM pan) and cam cap bolts can easily be done by hand, but my motor is in n' out so often i have the need for speed. A zipper would be best.
NOX
posted January 19, 2009 10:58 PM
For clutch springs, use a cordless drill on the 8 setting.......
42 Wins
21 Runner-ups
Sponsored by:
Scorpion Helmets
Galfer Braking
AMSOIL
Steve's Speed Shop
Conway Cycle
Syed Leathers
Johnnycheese
posted January 20, 2009 03:41 AM
yep
posted January 20, 2009 03:43 AM
yep
yep#2
posted January 20, 2009 04:19 AM
this will save me some time!
what setting do you use for the cover? (want to eliminate the torque wrench from clutch tuning)
posted January 20, 2009 04:31 AM
just do it by feel, neither the srews that hold the pressure plate on or the cover on are tq sensitive, just don't overdo it.
posted January 20, 2009 04:45 AM
im good at breaking stuff when i dont use a torque wrench. i think its genetic...
posted January 20, 2009 05:31 AM
Me too!
i am (now) good at inserts!
NOX
posted January 20, 2009 06:39 AM
I use a t handle wrench, and just get them snug....., when I put em back on, I set it on 6. RYOBI 12 V. Not too heavy, and like 38 dollars at HD, with two batteries
42 Wins
21 Runner-ups
Sponsored by:
Scorpion Helmets
Galfer Braking
AMSOIL
Steve's Speed Shop
Conway Cycle
Syed Leathers
posted January 20, 2009 07:57 AM
i use a ryobi at work some times, usually one of the 18v dewalts. got to use a tiny 12v makita once that worked suprisingly well. it had an impact setting that would put a 3.5in screw in as good as the non impact 18v dewalt
posted January 20, 2009 01:16 PM
My personal habit is to always use a very light setting in the power tool and ALWAYS final hand tighten (or torque) the fastener. There is no substitute for developing a mechanics feel to judge the integrity of a threaded fastener.
In my dealership this was the rule.
D.
posted January 20, 2009 01:22 PM
D.
I learned that lesson on the cam cap bolts.
I have had them off n on so many times they started, 1 by 1, necking.
By doing a light tightening with the power drill, then tightening/tqing, i could feel when a bolt started to neck and back it out before it separated.
After a few of em i bought a whole new set,
NINJA12
posted January 28, 2009 02:22 PM
Wal-mart has a SKILL brand of that battery powered 1/4 rachet for $25 on clearance.
Probably not as good, but I couldn't resist.
Hopefully I won't need it very much this year.
NINJA12
posted January 28, 2009 02:34 PM        Edited By: NINJA12 on 28 Jan 2009 22:34
http://www.walmart.com/catalog/product.do?product_id=7812621
it comes with the battery and charger.
0.22101306915283 seconds processing time
