BIKELAND > FORUMS > DRAGBIKE ZONE.com > Thread: Ultra 250X parts NEW TOPIC NEW POLL POST REPLY
rgeorge
posted January 04, 2009 03:40 PM        Edited By: rgeorge on 4 Jan 2009 23:43
Ultra 250X parts
Ultra 250X is a supercharged engine based on the ZX12R engine. Same 83mm bore, but stroked to 1500cc. The cylinder head and valve train appear to be very similar to the 12's
I am using 250X exhaust valves for my engine build.
Has anyone else tried 250X parts?
posted January 04, 2009 06:17 PM
be nice if the crank would fit... but since nobody has done it, it must be a big challenge. imagine that crank with an 87mm bore....
how do the valves/head compare? much diff?
rgeorge
posted January 04, 2009 07:59 PM
Crank drives a jet pump on the alternator side, no provisions for driving a clutch on the other end
Main Journals are 41mm, compared to 37mm in the 12R.
You can compare microfiche at cheapcycleparts.com (RonAyers doesnt show many PWCs)
rgeorge
posted January 04, 2009 08:24 PM
The STX-15X is also similar but not supercharged. Many of the part numbers for the head/valvetrain are the same for both crafts and the bike.
I am most interested in the parts that changed for the 250X. Kawasaki engineers made some changes so the engine would handle 250hp. I intend to make similar upgrades to my 12.
posted January 04, 2009 10:48 PM
Rob,
what is the difference between the 250X exh valves and the ZX12????
rgeorge
posted January 04, 2009 11:23 PM
250X exhaust valves are Inconel. I measured one, it was dimensionally identical to my stock 12 valves.
Texas12R
posted January 05, 2009 02:48 PM
interesting choice of materials
posted January 05, 2009 04:25 PM
so they stand up to heat better than SS?
whitehendrix
fails!
posted January 05, 2009 06:48 PM        Edited By: whitehendrix on 6 Jan 2009 02:48
yeppers.. exotic metals rock.
same material a turbo's turbine wheels are crafted from.
occasions. - ZRXDean
ill never own a busa unless
ill sell it -KZScott
posted January 05, 2009 07:22 PM
When the supercharged boat engine first came out we looked pretty carefully at it and if it could be used in any way.
Basically, no.
If you were building a top fuel bike with no transmission, the cases could be a bonus, but pretty much everything else is boat specific. You can already buy any parts you want to improve the ZX-12 engine to any level you wish, much easier than trying to "adapt" parts that are clearly not designed for that use.
Inconel exhaust valves were probably chosen because of the sustained high valve temps you get in a boat (wide open for long periods of time). Very common in diesels and turbocharged aircraft engines as well.
Doug
posted January 06, 2009 06:53 PM
isnt the crank about a 14mm stroker when compared to the 12? hello 1650cc with a muzzy block ... if only it was compatible
Rob, you going with a blown alky setup or just super high cr?
posted January 07, 2009 09:48 AM
Yeah, If only.......
posted January 07, 2009 05:05 PM
this may sound silly, but what about just mounting on the supercharger?
rgeorge
posted January 07, 2009 09:52 PM
Buiding a blower bike would be fun, and riding it would be a blast! But the frame/airbox is in the way!
Ares
posted January 07, 2009 10:01 PM
the Mono frame can be sealed, but yes pain in the ass.... go for it anyway! the reward will be worth it. If you can tig its just time
almost_les
posted January 08, 2009 12:39 PM
fukkame! i called the local dealer and they were about $42 a pop. anyone know where i can get some cheaper?
posted January 08, 2009 10:25 PM
Did you guys ever see the blown and injected ZRX we built at Muzzy in 99 or so? I did the tuning / testing. It was EXTREMELY fun to ride. Have a look-
Here's a link http://www.sportrider.com/features/146_0502_kawasaki_zrx1200/index.html
D.
posted January 08, 2009 10:29 PM
a bit better on cheapcycles $34.25
ss are a hair under $20 on Schnitz
posted January 08, 2009 10:52 PM
D.
that was a good read. my dad wants a blower on his 12 in a few yrs. by then ill go turbo
almost_les
posted January 12, 2009 11:59 AM
sold some parts, should be getting me a set of these little jewels pretty soon. thanks for the info guys!
posted January 12, 2009 12:02 PM
getting bronze seats too?
almost_les
posted January 15, 2009 01:20 PM
wow, 290 shipped! still, cheaper than a blown up motor. now for some pistons... i'm thinking mtc's turbo set, but thats next paycheck, TBC...
posted January 15, 2009 06:30 PM
turbo pistons... you spraying a 150+ shot?
almost_les
posted January 16, 2009 12:15 PM
sorry, thats top secret
posted January 16, 2009 12:28 PM
should be a wheelie good time
0.21724510192871 seconds processing time
