BIKELAND > FORUMS > DRAGBIKE ZONE.com > Thread: valve pockets and os valves NEW TOPIC NEW POLL POST REPLY
posted December 03, 2008 03:33 PM
If I run 1mm over size EX valves with JE 1287 pistons would I have to modify the piston to take the bigger valve or are they generally made with slightly larger pockets for os valves?
posted December 04, 2008 08:13 AM
YOU "MUST" Specify the valve size! The reason I do not use JE is they missed by 0.004 to 0.009 on a few pockets and it was not a good thing either!
posted December 04, 2008 07:23 PM
IN 33.39mm
EX 28.35mm
got a reply from JE stating the valve pocket diameters are
IN 37.084mm
EX 31.750mm
what do you mean by missed? how did you check?
brickman
posted December 05, 2008 05:24 AM        Edited By: brickman on 5 Dec 2008 13:56
i do a lot of racing down this way. i did not won't to leave that up to long. sorry.
posted December 05, 2008 05:37 AM
thx brickman ...damn.... I wonder whats causing them to snap? Karl has had good luck with big cams. im just running 2 intakes, and carpenter springs. I may end up just sticking with stock sized valves and bronze seats.... what kind of performance gains were you told the big valves give?
Y2KZX12R
CompetitionCNC.com
posted December 05, 2008 05:40 AM        Edited By: Y2KZX12R on 5 Dec 2008 13:43
Brickman, Ouch
What brand valves and springs are you using?
Do you run Nitrous?
Does it have Bronze seats?
Y2KZX12R
CompetitionCNC.com
brickman
posted December 05, 2008 05:53 AM
Brickman, Ouch
Do you run Nitrous?
i don't know what brand they are. carpenter has done all the work on it so who ever they use. i think bob said ape? but don't quote me on that. and #3 was the only one to have bronze seats. they were put in when it was fixed the first time.
brickman
posted December 05, 2008 06:14 AM
you no the funny thing is i put a stock head on that motor with just a nice port job. stock cams and springs and it done the same thing with the # 3 ex valve? i got some pics of both heads some were. i could email to some one to put up for me.
brickman
posted December 05, 2008 06:17 AM
i am off to work . i'll look for them when i get home.
posted December 05, 2008 07:07 AM
send them to me and ill post them
s_u_fire@hotmail.com
posted December 05, 2008 09:08 AM
i missed something...
I am keenly interested in head work, yep.
been doing LOTS of experiments with heads
Just sent one to Jim
TRNorBRN6001
posted December 05, 2008 09:27 AM
Yep, I missed it too.........
TFA 200MPH CLUB MEMBER!
brickman
posted December 05, 2008 12:20 PM
thanks they are on this pc. should not be hard to find. i'll email them to you as soon as i do.
brickman
posted December 05, 2008 12:32 PM        Edited By: brickman on 5 Dec 2008 20:32
you did not miss much. we were just talking about ex valves. and i had a post up about some work on a motor that i have been having problems with. i done a way with the post. i just felt better with it gone. don't really know why. it ant like my junks fast or any thing.lol
posted December 05, 2008 12:51 PM
brickman,
if there is a problem w/valves, i've had it
solved most of em with help from folks here.
flite leader
posted December 09, 2008 04:53 PM        Edited By: flite leader on 10 Dec 2008 00:58
oversize valves are only good if they are as shallow as they can be
sink them into the head & they wont flow anymore that what you took out
its better than your pistons are flycut for the valves youare using
its also a given that you will check that clearance on assembly
which means putting it together & taking it apart at least once
unless you have used that identical parts list b4
otherwise a tapped or broken valve will destrouy
the valves in that cylinder..... at least 1 piston
the head totally & possibly the crank...................................last but not least the cylinder block
no less with you running NOS in some ways not a good idea to increase valve size
you are really gaining HP on NOS not Volumetric efficiency
you ALWAYS want to stay OFF the rev limiter....................ALWAYS ! ! ! ! !
that causes the valves to tap dance off their seats
screws up the air fuel ratio inside any or all the cylinders
which will cause you some problem$
bend your mind.....
or break your ass...!!
0.21566796302795 seconds processing time
