BIKELAND > FORUMS > DRAGBIKE ZONE.com > Thread: Test - N - Tune Gainesville 11-07-01 NEW TOPIC NEW POLL POST REPLY
harryzx-12
posted November 07, 2001 08:55 PM
I'm pretty happy with my results tonight.I had my best ET and MPH ever 10.524@137.14 and 10.54@ 139.68. My other times were 10.63,10.71,10.72,10.75 and 10.82was my slowest run of the night. I still need to improve on my 60 ft. times most were 1.9 with one 1.8.
Kevin ran his best pass ever with a 9.18@149 he also ran a 9.21.
Dean was running in the 9.7's.
Spiderman and chip ellis were there running kawasaki vulcans for fun! I asked spiderman was he sure he could handle all that power! His normal Kawasaki dragbike has 1000 HP and runs on nitromethane.
My clutch needs a little attention as it was dragging pretty bad at the end of the night.
posted November 07, 2001 09:12 PM
Go get them Harry!!!!
Hey dude what map are you using??? I might have a littl trick you can try and pick up a tenth or so?? email me your map tonight and let me make a change to it for you if you would like..
mad mike
harryzx-12
posted November 07, 2001 09:36 PM
I have an Akro pipe mike and you are running a muzzy aren't you? I appreciate the offer. I can't go full throttle in 1st or second gear without slipping the hell out of the clutch.My tire did break loose in 2nd gear one time pretty bad , fuckin street cars dripping shit on the track. The track is so sticky I didn't do anything but spin the tire a little to clean it off.No wheel spin except for the one time.
kcadby
posted November 07, 2001 10:21 PM        Edited By: kcadby on 7 Nov 2001 23:46
17/51 gearing axle TO THE BACK of the 6-over swingarm...WORN OUT TIRE at 10PSI...
Spun a tiny-bit then power wheelied in 1st...shifted 2nd in the air...would have made a COOL video but Doomass me left the camera in my car at the shop...stayed in the air all the way through 2nd which was over in a flash with the new gearing...
3rd...4th...5th...run over...DAMN THAT WAS FUN!
Got there late...here are both of the runs I made tonight...
I wimpped out on the launch on the last run (no wheelie) making sure it didn't spin...
NEED the new tire...
Can't launch nearly as hard on the throttle with this gearing (as expected) but it was definitely easier on the clutch also...
posted November 07, 2001 10:48 PM
17/51 ... I should try that on the street!
0.28306102752686 seconds processing time
