ZX12R_NJ
Stretched ZX12
posted October 26, 2008 07:18 AM
New To Dragging
I have been riding for a while now. I have an 03 ZX12. Stretched 6" over. I have already been finding a ton of useful information on here. What are roundabout quarter times for the 12's. Bike is stock minus K&N and full Muzzy system. My biggest problem is launching the bike. I started looking into launch limiters, but most dont seem compatible with the 12. So aftermarket ignition like the ARC-2 seems like good idea. Any pointers would be great. In process of air shifter install. Considering 50hp wet system...But want to be strong on all motor before going with adders.
BrooklynNYZX12
posted October 26, 2008 02:37 PM
I have an 03 ZX12 as well, I am over 200 lbs in leathers.Stock wheelbase 16-44 gearing,foot shifting Muzzy pipe no Power Commander my personal best e.t was 9.71 @146. Rick a.k.a. CrotchRocket has gone a 9.50 @148 on my bike.It took me alot of practice to get in the 9's with the bike so before you start modifying your bike any more I would practice practice practice.CR has run in the 9.30's with his bike so the 12 is plenty powerful it seems to need a bit of throttle/clutch finesse to get a good e.t's.Get some quality seat time at a Jason Miller Streetbike Seminar or get to as many track rentals as you can and good luck with your 12!
Orient Express Top Street Bike Winner 8-4-07
posted October 26, 2008 03:10 PM
try 17 50 gearing. strap the front end. practise
ZX12R_NJ
Stretched ZX12
posted October 28, 2008 08:54 AM
What would you say an average 60' time is on a 12? What did you guys run starting out (assuming it was on a comparible bike)? I dont remember my most recent off hand but i know my launching is my weak point.
posted October 28, 2008 01:18 PM
Depends on how long your 12 is, and how aggressive you are...
BUT, the 12 does not 60' like a Busa or a 14...Another But, it sure back halfs faster then the Busa and 14 !!!
Once you learn how to treat the clutch right, then you will start to get some longevity as long as you have the right set up, as you do since you have the 2003 zx12...Unless you changed the OEM clutch set up???
Stock wheelbase you'll see high to mid 1.6s and low 1.6s as you get better...
With it extended mid to low 1.5s and when you get good then 1.47s to 1.50s with low 3.90 330s too!!!...All with a stock clutch...
If you go with a lock up, you'll get faster 60' and 330s when you get the right clutch tune up...
NOX
PMRA / TMRC Super Street 4022
posted October 28, 2008 03:00 PM
With an arm, and the right set up, mid 1.3s are do able.., and 3.7 330s, all day.
And the clutch will actually last doing that.........
42 Wins
21 Runner-ups
Sponsored by:
Scorpion Helmets
Galfer Braking
AMSOIL
Steve's Speed Shop
Kawasaki Sports Center
Mickey Thompson Tires
Catalyst Racing Composites
Conway Cycle
Syed Leathers
ZX12R_NJ
Stretched ZX12
posted October 28, 2008 03:35 PM
I have a welded in 5.5-6.0 over arm. done by treat racing in jackson. other than that bike is pretty much stock . No work done to clutch at all. I have heard from some other people that I should put heavier clutch springs. I have made 5 passes without the front strapped. But the bike cant get any lower because I do street ride as well. I have scraped the oil pan on a few really bad bumps. I cant wait til the atco opens back up.
NOX
posted October 28, 2008 04:40 PM
High 1.4s should be no prob when you get set up. Especially when you get a lower pan........
Street and strip, you cannot have the best of both worlds.........
42 Wins
21 Runner-ups
Sponsored by:
Scorpion Helmets
Galfer Braking
AMSOIL
Steve's Speed Shop
Conway Cycle
Syed Leathers
posted October 28, 2008 07:59 PM
the best part about a strap is that you just release it when you drive on the road, and pull it tight when you are at the track. it works not only by lowering the front end, but a big part of how it helps is limiting front wheel travel
