aliveagain
posted October 24, 2008 07:03 AM
Wrapping the exhaust
I'm thinking about wrapping my stainless Muzzy pipe.How much does it take,is 50' enough?I also notice they come in different thicknesses also,1/8" or 1/4",does it matter?Some come with tie wraps,won't they melt?Safety wire instead?
NINJA12
posted October 24, 2008 08:05 AM
Looking into the Jet coatings as well.
I hear there are some good stuff out lately.
Stuart Racing
N.H.R.A . Dragracing.
posted October 24, 2008 02:06 PM
I did mine and ya better get 2 rolls of the wrap....I used the 1" wide stuff and saftey wire....I couldn`t get the straps tight enough to keep it from slipping....Worked good for me....
P....
aliveagain
posted October 24, 2008 02:15 PM
thanx,was it 1/8" or 1/4"?
NOX
PMRA / TMRC Super Street 4022
posted October 24, 2008 03:52 PM
Same here. But, its a pain, wish I would have ceramic coated it..........., I just ended up taking it off........
42 Wins
21 Runner-ups
Sponsored by:
Scorpion Helmets
Galfer Braking
AMSOIL
Steve's Speed Shop
Kawasaki Sports Center
Mickey Thompson Tires
Catalyst Racing Composites
Conway Cycle
Syed Leathers
Stuart Racing
posted October 24, 2008 04:13 PM
quote: Same here. But, its a pain, wish I would have ceramic coated it..........., I just ended up taking it off........
What was a pain about it NOX????
What are you talking about 1/8" thickness....I didn`t notice any thickness with the stuff I got....Iwould imagine the 1/8 stuff....
tcchin
posted October 24, 2008 04:34 PM
I've found that soaking the wrap in water will help it stretch and conform, making it easier to install. I use worm-drive hose clamps to hold it in place. As for thickness, you need to be careful that you don't over-insulate the pipe or it will be prone to cracking.
posted October 24, 2008 05:52 PM
i think the stuff i used was 1/8 by 2 inch. like tim says, soak it in water. some stuff comes with really nice stanless ties. ive seen a lot of it on the cars @ the track. i just used some steel wire and its holding up fine. quite a bit of heat difference. i like it. get the black stuff, it goes to a charcoal colour, the white stuff goes yellowish
aliveagain
posted October 24, 2008 06:45 PM
Good info about soaking it.I thought about it for awhile and the 1/8 sounded better.
aliveagain
posted October 25, 2008 07:33 PM
got this off hayabusa.org some good pics on page 4
http://www.hayabusa.org/forum/busa-mods/78738-muffler-cloth-tape-headers.html
looks like 50' of the 2" wrap would be enough.
BrooklynNYZX12
posted October 25, 2008 08:21 PM
Why do you want to wrap the header?Have seen the wrap getting the headers unusually hot and making the headers brittle.Look into a ceramic coating I had my Muzzy header Jet Hot coated and am satisfied with the results.Dont bother wrapping.
Orient Express Top Street Bike Winner 8-4-07
tcchin
posted October 25, 2008 08:52 PM
Depending on how much overlap you use while wrapping, along with the thickness of the material you use, you can over-insulate the pipes and cause a problem. If you use relatively thin material and limit the overlap to 25% as many wrap manufacturers recommend, then you should be okay. I don't know if I would recommend wrapping headers on an endurance roadracing engine, but a drag racing application shouldn't generate heat for a long enough time to be a problem.
aliveagain
posted October 26, 2008 01:16 PM
quote: Why do you want to wrap the header?Have seen the wrap getting the headers unusually hot and making the headers brittle.Look into a ceramic coating I had my Muzzy header Jet Hot coated and am satisfied with the results.Dont bother wrapping.
I didn't want to spend $300 to coat the headers.It started as just reading about them and my obsessive/compulsiveness took over.In all that I have read,wrapping will help scavenge the exhaust and help keep the velocity up.This bike does see street riding and it can get up in temp during stop and go city traffic.By wrapping the pipes and putting insulation under the frame,I'm trying to move the heat further back.Cooler inlet air also as a side benefit.You're right, I probably don't need it,but for $40 it couldn't hurt.
Stuart Racing
posted October 26, 2008 03:05 PM
My thought exactly.....With the wrap, you can actually put your hand on the pipe with it running.., with the coating you can`t touch it,too hot....Anything to keep the heat away from the engine,ect.ect.ect....can`t hurt....And the scavaging is a plus also....
P....
posted October 26, 2008 03:11 PM
just dont wrap a TI system
Texas12R
posted October 26, 2008 03:58 PM
Edited By: Texas12R on 26 Oct 2008 23:58
yep someone has pics of a Ti pipe with tiny holes . They discovered this after unwrapping
to do a re-wrap.......I think it was Blitz....he had alot of good info.....
Good of Scott to remind everyone
oh yea.....I reserve the right to be wrong
NOX
posted October 26, 2008 04:38 PM
Its a scavenging thing mainly.....
I did soak mine. When you change the oil, with either the coby pan, or especially the Koenig pan, you get oil on the header, and it takes forever to smoke off........
42 Wins
21 Runner-ups
Sponsored by:
Scorpion Helmets
Galfer Braking
AMSOIL
Steve's Speed Shop
Conway Cycle
Syed Leathers
Y2KZX12R
CompetitionCNC.com
posted October 27, 2008 04:01 AM
Edited By: Y2KZX12R on 27 Oct 2008 12:09
Pete, I use the 2" wide 1/8" thick stiff. I wrap it dry and tight. Then I use .025" stainless safety wire to seccure. You will neeed to get a pair of safety wire pliers to spin the wire tight.
This yosh pipe is 8 years old now and has had no problems. It has 18,000 miles of hard street riding and many dozens of dyno pulls.
You will get some added discoloration of the mid pipe before the muffler due to the heat retention.
Y2KZX12R
CompetitionCNC.com
