BIKELAND > FORUMS > DRAGBIKE ZONE.com > Thread: Air tank/compressor question NEW TOPIC NEW POLL POST REPLY
krexken
posted October 22, 2008 12:56 PM
A friends bike has the onboard compressor hooked to the air tank with the original inflator/chuck thingy It tends to pop off the bottle and is a major pain to get to. There's a shrader valve in the tank where the air chuck thingy clamps on. I'd like to cut off the air chuck thing on the compressor hose and replace the shrader valve with a hose barb fitting and clamp it on there. Does the system need the shrader valve in the tank or will the compressor hold pressure pretty well. Thanks
BTW, you can safely cut .023 off of zx14 head and still have good PTV clearance.
icarus
posted October 22, 2008 03:11 PM
You will need a check valve between the compressor and the tank. It has to be installed
so the valve will hold the pressure in the tank and allow the compressor to unload when
it is done cycling. As for using a hose barb, make sure the compressor hose does not
have a teflon lining because it may not stay on the barb very well. Think about other
options before cutting the chuck off otherwise you may end up ruining your compressor.
8.820 @ 161.05
ninja12
posted October 25, 2008 05:20 AM
The check vavle(shrader) is held open with the air chuck.
Meaning the only time it helps is when the hose pops off.
The barb will work just fine, but you could put a "T" in the line a keep the shrader for a back-up. Just run it somewhere you can get to it quick and easy. You could use Aux air supply when your pump dies at the track, or you are testing at the shop.
I really like this setup with push on connectors because it give you extra hoses and a chance to repair your system at the track.
0.23856616020203 seconds processing time
