BIKELAND > FORUMS > DRAGBIKE ZONE.com > Thread: who + where ? undercut zx12r trans ---- NEW TOPIC NEW POLL POST REPLY
woppi
posted October 22, 2008 05:36 AM
please give me your know how
who + where is the best company to undercut my zx12r trans ???
for my zx12r nitrous bike
thanks
woppi
1st TFA Member / Austria !
2000 Limited ZX12R NOS
NOX
PMRA / TMRC Super Street 4022
posted October 22, 2008 06:26 AM
R n D.
Look no where else. Get the WORKS.
42 Wins
21 Runner-ups
Sponsored by:
Scorpion Helmets
Galfer Braking
AMSOIL
Steve's Speed Shop
Kawasaki Sports Center
Mickey Thompson Tires
Catalyst Racing Composites
Conway Cycle
Syed Leathers
TRNorBRN6001
posted October 22, 2008 07:26 AM
RnD or Robinson.
TFA 200MPH CLUB MEMBER!
posted October 22, 2008 08:26 AM
R&D Motorsports did mine. no problems on my nitrous bike!
posted October 22, 2008 08:33 AM
info about the zx12 trans from R&D
5th gear only goes in half way. they do some fancy stuff to the shift drum, i think do some clearencing, and make a shoulder so that 5th goes 3/4 of the way in. its not possible to go all the way or it would be in two different gears at the same time(= broken teeth)
the HD clip mod uses a harley clip 11067 i think was the part number, and is 2mm wide. they have to do some machining and clearencing for it to work IIRC. this prevents not only the gear from popping in and out, but if your kill time isnt set high enough on an airshifter application, it can blow the stock clip out and the bike goes into 2 gears at the same time, and you start picking teeth out of your oil pan.
the billet gears(chrome molly) are hardened to 52-54 rockwell any more and they get brittle(not sure what stock gears are). they do wear faster than stock gears, but wont stress fracture. they start to show pitting after miles and miles of street use. (im hoping royal purple oil will help with this problem, look at their adds, more specifically pics of bearings before and after)
the 12 has smaller centerlines (i think that was the word) than the 11. the opposite of what should have happened, the 12 should have gone bigger because it makes more power. to compensate, they made the gears wider to spread out the force. this isnt an ideal fix as it causes "tip loading" and can cause stress fractures when you start making good power
posted October 22, 2008 10:59 AM
call them, talk to Mark. they dont have a website
1 727 447 4552
woppi
posted October 22, 2008 11:21 AM
1 727 447 4552
kzscott ----thx !!!
at which time ????
woppi
woppi
posted October 22, 2008 11:25 AM
where is R&D located ??
thx
woppi
posted October 22, 2008 03:05 PM
i cant remember their hours but i think between 8 and 4. they are in Florida USA
NOX
posted October 23, 2008 06:33 AM
Which makes the biggest issue of the zx12. When other guys are shifting, the 12 wont, because the window of engagement is SO small, because of the small centerlines........
The only real problem I have ever had with the zx12............., well, that and the fact that I can't bolt on lectron carbs.
42 Wins
21 Runner-ups
Sponsored by:
Scorpion Helmets
Galfer Braking
AMSOIL
Steve's Speed Shop
Conway Cycle
Syed Leathers
Stuart Racing
N.H.R.A . Dragracing.
posted October 23, 2008 10:30 AM
I think Paul Gast is making some adaptor boots with a curve in it to make the Lectrons sit more level....He makes them for the Busa,wich I don`t know if they would work on the ZX or not.....Worth a check into....
posted October 23, 2008 02:31 PM
Wolf has carbs on his big bike. i think they are lectrons... cant remember right off the top of my head...
NOX
posted October 23, 2008 03:01 PM
Yes, but that is a tube chassis. They will not fit in the stock frame.
42 Wins
21 Runner-ups
Sponsored by:
Scorpion Helmets
Galfer Braking
AMSOIL
Steve's Speed Shop
Conway Cycle
Syed Leathers
woppi
posted October 23, 2008 11:42 PM
NOX -- yes that´s right !!!
will not fit with the stock frame !!!!!!!!!!!
both bike´s ------------- ZX12r engine !!! ----- other frame !!!
both bike´s from czech republic
woppi
aliveagain
posted October 24, 2008 04:56 AM
So why not cut out the bottom of the frame?Would that be a structural problem or because you would lose the ram air?
NOX
posted October 24, 2008 06:05 AM
Structure..........
I assume. The ram air would not be used......
42 Wins
21 Runner-ups
Sponsored by:
Scorpion Helmets
Galfer Braking
AMSOIL
Steve's Speed Shop
Conway Cycle
Syed Leathers
aliveagain
posted October 24, 2008 06:43 AM
You already have holes there.Cutting it where the stacks go would only weaken it from folding inward,the side of the frame keeps the rigidity front and back,no?I would think that is where all the stress is,you still have quite a bit of metal for torque twist.
posted October 25, 2008 01:08 PM
Robinson Industries is who I used and they are VERY Serious about the work they do! In New York!
posted October 25, 2008 06:49 PM
Mark uses his molly gears.
0.26369214057922 seconds processing time
