aliveagain
posted October 15, 2008 07:25 PM
muzzy air shifter
I tried the air shifter out today and it didn't work.I am going to make sure the bottle had plenty in it to rule that out.My question is can I disconnect the solenoid from the shift linkage and test the air shifter on the lift?I just want to make sure I won't damage anything by it not being connected or have a distinct stop.I know not to try it while attached at an idle.
posted October 15, 2008 08:23 PM
Leave it fully connected turn the key on DONT START IT and press the button for the shifter...
posted October 15, 2008 08:58 PM
pete,
i'd just pull the hose from the shifter piston or solenoid, start motor and hit the button.
you oughta hear the gas psssshht AND an interruption of the motor
NOX
PMRA / TMRC Super Street 4022
posted October 15, 2008 09:34 PM
DO NOT press the button for the shifter, with the ram connected......., you will bend the shift forks..........
It is a Muzzy system, therefore it MUST be your fault that it is not working. Just ask Dave or Kurt.
42 Wins
21 Runner-ups
Sponsored by:
Scorpion Helmets
Galfer Braking
AMSOIL
Steve's Speed Shop
Kawasaki Sports Center
Mickey Thompson Tires
Catalyst Racing Composites
Conway Cycle
Syed Leathers
aliveagain
posted October 16, 2008 02:31 AM
I wondered about that,whether I wanted to hold the tube under pressure or at least energized.I have to find the set up instructions for it to see if I properly installed the ram.Do you make sure the ram is all the way in and then clamp it around the linkage or is there another way?I just saw on Muzzy's web site how the digikill cuts the injectors while shifting.Yow shizzam,not good while spraying.
Nox,of course it's my fault,I'm the mechanic.It worked before so I'm tending to look at something mechanical then electrics.
posted October 16, 2008 03:46 AM
hitting the button with the tube disconnected (runs from the solenoid to the piston) will just generate a momentary blast of CO2 or N2O and will show you if the solenoid is working.
The lil stumble in rpm will show you if the kill is working.
that way you don't hurt anything.
When connected to the shift linkage, the ram has to be extended the right amount so it can pull the linkage just the right amount. The directions give that extension amount.
posted October 16, 2008 03:49 AM
pete do you have a digikill 2 or digikill 3??
digikill 2 is notoriously problematic and muzzy will replace with a dk3 if it fails.
woppi's failed and dave turner just sent a replacement to me
(woppi i will send it to you on fri or sat)
posted October 16, 2008 04:46 AM
quote: DO NOT press the button for the shifter, with the ram connected......., you will bend the shift forks..........
I accidentally hit the button the other day with it connected. I nearly shit my pants in fear. The bike is shifting fine now(it was in 1st and shifted up to neutral when I hit the button). I mean, is it 100% going to bend the forks every time?
Then I got to thinking about things a bit. What happens if the kill isn't set right and it tries to shift but won't go in....isn't that just as dangerous? Or what about trying to shift it up to 7th gear? I don't really understand the inner workings of the transmission, so humor me...
NINJA12
posted October 16, 2008 06:38 AM
All these thing can damage the shift forks, How many times you get away with is is like unprotected sex. Sometimes you get lucky and sometimes you pay.
aliveagain
posted October 16, 2008 11:49 AM
I got N2O out the tube but didn't hear anything at idle.I looked around the garage and couldn't find tha installation instructions for the shifter kit.Nothing on Muzzy's site either.Could someone Email me them if they have it thanx.
posted October 16, 2008 01:07 PM
crank the kill time to the max, hold it @ something like 4000 rpm. it should be very noticable when it kills the motor. ive been pulling the pin out of the shift lever to test of my switching valve and ram were working. i do it every time i put a bottle on to make sure its working.
aliveagain
posted October 16, 2008 07:15 PM
What is the setting for the solenoid shaft?How far out should it be extended?
ninja12
posted October 17, 2008 04:48 AM
I adjust where it just goes into first without much more.
Use all the travel for up shifts.
posted October 17, 2008 12:25 PM
i put the ram about half n half. that what most instructions say. make sure its close to 90 degrees from the lever
ninja12
posted October 17, 2008 05:53 PM
quote: i put the ram about half n half. that what most instructions say. make sure its close to 90 degrees from the lever
Depending on the mount you may not have enough linkage to get all the gears.
aliveagain
posted October 17, 2008 07:11 PM
So what happens if the adjustment is off?Will it bend the shift forks?Doesn't matter as the motor blew today.I whacked the throttle at 30mph and it instantly went to 12500rpms hitting the rev limiter.Knocking noise down low. Fun while it lasted,I'm actually excited about taking it apart again.
posted October 18, 2008 12:59 AM
damn... did the clutch slip that bad or did it just rev that quick? tire spin?
my knowledge on shifters is at its limit so ill let someone else answer the tough questions.
posted October 18, 2008 04:55 AM
quote: So what happens if the adjustment is off?Will it bend the shift forks?Doesn't matter as the motor blew today.I whacked the throttle at 30mph and it instantly went to 12500rpms hitting the rev limiter.Knocking noise down low. Fun while it lasted,I'm actually excited about taking it apart again.
WTF?????!!!!!!!
how the dickens did the motor go S by just one trip into the limiter??
didn't you just put it together???
what is going on??
aliveagain
posted October 18, 2008 05:29 AM
I know the clutch didn't slip with the lock up.I normally have 30psi in the tire for the street and it was a wham, bam, thank you mam.I came out of the wheel spin and the engine sounded a little off.Thought maybe I bent a valve but won't know until she's opened up. On the lift it sounded lower though.
posted October 18, 2008 08:04 AM
were you running tight quench height?
