posted October 10, 2008 04:22 AM
Edited By: entropy on 10 Oct 2008 12:23
charging system: Tim Chin = moto-wikipedia
Is there anything Tim Chin doesn't know about motorcycles?
My charging system was putting out 12.5V at the battery.
I did all the tests in the OEM manual (except regulator which requires 3 batteries) - no luck.
Got a new regulator - no luck (thx anyway JC/RALF!)
cursed, poked, prodded, walked around the bike 10 times - no luck
went into the house got a couple beers, then cursed, poked, prodded, walked around the bike 10 times - no luck
Then Tim sent me a detailed "if-then" set of instructions for systematically analyzing charging system problems.
At 2am, Badda-BING!
Bad connection somewhere between the regulator and battery. Jumped pos reg output straight to batt + and got my 14V.
I still have to isolate the bad connection but at least i know where the issue is
Tim Chin is a mightysmart feller
Thanks Tim, I owe you another one!
ZRXDean
posted October 10, 2008 07:19 AM
Suh-weet. Could the low voltage (although 12.5 doesn't seem so bad) lead to poor spark?
NINJA12
posted October 10, 2008 07:54 AM
I'd say YES, Some bike run crappy with a low battery.
ZRXDean
posted October 10, 2008 08:33 AM
Lotta drag bikes run total loss systems, I can't imagine they run much higher than 12.5V?
posted October 10, 2008 09:52 AM
Edited By: entropy on 10 Oct 2008 17:53
now its putting 13.7/13.9 @ 2000/5000rpm w/headlights, and 13.8/14.2 wo/ headlights hooked up,
so it is in spec.
i am told that low voltage can impact fuel pump & spark possibly leading to decrease in hp.
I will see tomorrow at the dyno
:fingas crossed
The hp that got me a bit over 200 @ Maxton sure won't do the trick at Texas. A lil more would be good!
ZRXDean
posted October 10, 2008 10:01 AM
Good luck Karl, looking forward to reading about the 20hp you find.
tcchin
posted October 10, 2008 12:57 PM
I'm not sure if regular, unannounced visits from Murphy make a person any smarter, but keeping a journal of those visits sure leads one pack a whole lot more stuff when one goes to the track!
Please note that checking the diode pack in the regulator does not require a separate battery if your multimeter has a "diode check" function built in. If you don't have a digital multimeter, I can recommend the following from personal experience. It's cheap, has a lot of functions and is accurate enough for automotive (motorcycle) applications. I have done some circuit design/testing with it, but not in applications that required high accuracy.
http://www.harborfreight.com/cpi/ctaf/displayitem.taf?Itemnumber=37772
posted October 11, 2008 10:40 AM
Edited By: entropy on 12 Oct 2008 05:58
well...
my fully functional charging system had NO impact on hp at the dyno ...
at least it is running fine, ready for the Texas Mile. Mid 190's here i come! (again).
hmmmm.....
posted October 13, 2008 12:52 AM
got an idea of what may be going on wrt hp, a solid idea, and as usual the nut behind the wheel is probably me...
(to be continued)
ZRXDean
posted October 13, 2008 06:10 AM
Sorry the regulator was not the culprit, but keep us up to date with the new possibility. You not holding it WOT? har har har.
TRNorBRN6001
posted October 13, 2008 07:00 AM
Sorry to hear that Karl, but at least your bike is charging now. Keep us up to date on that issue, hope you can Iron it out in a couple weeks.
TFA 200MPH CLUB MEMBER!
posted October 13, 2008 12:26 PM
we are working it; i am cautiously optimistic
osti33
posted October 13, 2008 02:18 PM
Edited By: osti33 on 13 Oct 2008 22:19
quote: we are working it; i am cautiously optimistic
Keep after it.
NINJA12
posted October 22, 2008 09:31 AM
Well?
posted October 22, 2008 11:02 AM
status? what else has been tried?
