BIKELAND > FORUMS > DRAGBIKE ZONE.com > Thread: putting a new basket on ring gear ? NEW TOPIC NEW POLL POST REPLY
dunedog
posted September 26, 2008 08:02 PM
I have a 01 zx12. The clutch basket fell apart. I found one from someone on this web site.With the dealer only selling the gear and the basket already connected together,I wonder if any one has connected them together and if so how. Do you use the old rivets ? Do you need to heat treat them if they can be used.Also my center clutch hub has some grooves in it.would it be possible to file them out a little.I know I should just save up and buy a billet basket and all new parts but i haven't been able to ride for about a month now .
TJ
posted September 27, 2008 04:33 AM
we put muzzys billet basket kit on dads ring gear.(cheapest option to get a billet basket) that uses bigger rivets that you weld on the back. i believe that the stock rivets are pressed in(i had to drill them out)
you can use a small flat file to take grooves from the hub. i did it to mine
0.30167198181152 seconds processing time
