BIKELAND > FORUMS > DRAGBIKE ZONE.com > Thread: quick motor question NEW TOPIC NEW POLL POST REPLY
posted September 01, 2008 06:46 AM
do i have to fully remove the motor to take out the stock head bolts to replace with APE studs, or will i have enough room by just tilting the motor down by leaving the lower rear bolt in the frame/motor?
thx guys!
aliveagain
posted September 01, 2008 08:14 AM
You could probably just lower the motor by tilting it,however putting the cylinder back on would be more of a pain then sitting on a bench.Or were you planning on threading the studs without removing anything but the cams and cap?
posted September 01, 2008 09:04 AM
the plan is to just take out 1 bolt and replace it with 1 stud at a time, leaving as much together as possible! I want the head torqued on that extra 7 ft#s for next wknd as im planning on spraying it
aliveagain
posted September 01, 2008 02:33 PM
Hell,I wouldn't even take the exhaust off.Just unbolt from rear mount and unbolt radiator from the frame.I did find I needed to pull the chain off the rear sprocket.The hardest part for you would be your NOS system.
posted September 01, 2008 03:34 PM
i was thinking that at least the header should be able to stay as is .
more on the nitrous in the other thread
aliveagain
posted September 02, 2008 06:09 PM
I mentioned that because the velocity stacks will have to come off and then reassembled on when the engine is lifted back up.If your nitrous is not bolted down with thestack bolts,your golden.
Nox
PMRA / TMRC Super Street 4022
posted September 03, 2008 06:13 AM
loosen the boots to the throttle bodies......., thats the easiest........
42 Wins
21 Runner-ups
Sponsored by:
Scorpion Helmets
Galfer Braking
AMSOIL
Steve's Speed Shop
Kawasaki Sports Center
Mickey Thompson Tires
Catalyst Racing Composites
Conway Cycle
Syed Leathers
posted September 03, 2008 06:53 AM        Edited By: KZScott on 3 Sep 2008 07:54
the foggeres are held down by 1 stack bolt. i may be able to get them out without removing lines.
Nox, so leave them hanging from the stacks?
ninja12
posted September 03, 2008 07:39 AM
yeap. and roll the motor back onto them.
You will have to tilt them at the right angle by hand when you go back up.
they will pop right back in place.
Nox
posted September 03, 2008 03:45 PM
YUP.
especially if you have bear stacks........
42 Wins
21 Runner-ups
Sponsored by:
Scorpion Helmets
Galfer Braking
AMSOIL
Steve's Speed Shop
Conway Cycle
Syed Leathers
Nox
You will need a very long allen wrench........., but worth it........
42 Wins
21 Runner-ups
Sponsored by:
Scorpion Helmets
Galfer Braking
AMSOIL
Steve's Speed Shop
Conway Cycle
Syed Leathers
0.25357508659363 seconds processing time
