Lorcan
posted July 12, 2008 04:14 AM
Storm
Hey guys, I thought you might like to see our little project, which is nearing completion. Storm is the creation of Barry Eastman and Mick Hand with help from Angus McPhail and myself. I'll also be the ballast.
The bike has a 1500cc Puma engine with a custom made 16 valve head. It has two turbos in series (compounded), so one turbo blows into the second turbo, multiplying the boost. It can make up to 120psi. It has liquid cooled intercooling between each stage, and the liquid is cooled by CO2. It has Motec fuel injection with 16 injectors running on methanol, and NLR AMS1000 boost control. It is 105" wheelbase and weighs 850lb.
We are hoping to test at the end of the month.
Enjoy
810cc - 211mph: www.750turbo.com
Lorcan
posted July 12, 2008 04:18 AM
02zx12rbob
posted July 12, 2008 04:31 AM
Nice
posted July 12, 2008 04:34 AM
hey Lorc, how do you even start to come up with a fuel map?....damn... excellect work!
aliveagain
posted July 12, 2008 05:50 AM
any pics of the head before install?
Lorcan
posted July 12, 2008 08:21 AM
No, sorry. I can tell you that the bottom half is made from solid, and it has Yam FJ valve gear bolted to it. It has no skulls, and the valve seats are cut into the head itself, not separate.
Lorcan
posted July 12, 2008 08:26 AM
quote: hey Lorc, how do you even start to come up with a fuel map?....damn... excellect work!
Our Motec guy can put in a calculated map that will get it near enough to get up the track, then we will tune with EGT and lambda.
NOX
PMRA / TMRC Super Street 4022
posted July 12, 2008 08:48 AM
OMG
42 Wins
21 Runner-ups
Sponsored by:
Scorpion Helmets
Galfer Braking
AMSOIL
Steve's Speed Shop
Kawasaki Sports Center
Mickey Thompson Tires
Catalyst Racing Composites
Conway Cycle
Syed Leathers
shane661
posted July 12, 2008 08:55 AM
I would be interested in seeing the math behind the compound turbo setup. I've never see a setup like that before.
woppi
posted July 12, 2008 09:11 AM
that´s a BIG Storm !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
woppi
1st TFA Member / Austria !
2000 Limited ZX12R NOS
stuart racing
N.H.R.A . Dragracing.
posted July 12, 2008 09:31 AM
WOW,UN FREAKIN BELEIVABLE LORCAN.....You can hardly even find the motor...You got your hands full with that beast....YIKES....
P....
Lorcan
posted July 12, 2008 09:45 AM
quote: I would be interested in seeing the math behind the compound turbo setup. I've never see a setup like that before.
It's a popular technique in tractor pulling, some of those have 4 turbos in series and can make 250psi. It's covered in the Hugh McInnes book "Turbochargers" if you want to read up on it. As far as I know we are the first to try it on a bike.
shane661
posted July 12, 2008 09:47 AM
Thanks for the info, and good luck with the project!
aliveagain
posted July 12, 2008 02:19 PM
LOL, Nox, you got a set up for that clutch?Big balls to crack that throttle on the line.Hope we get to see some videos.
posted July 12, 2008 06:39 PM
the air nailers at work run on 120 psi.... thats just crazy for a motor. im guessing you change the oil after every pass?
posted July 13, 2008 01:01 AM
awesome!
ZXLNT
posted July 13, 2008 06:32 PM
SPROING!!!!!
zx12mark
posted July 13, 2008 08:16 PM
your going to fucking levitate!------like the JETSONS.....please post some vid when you pull the trigger.
zrxdean
posted July 14, 2008 07:52 AM
Holy bejeezus Lorcan, hope you have good upper body strength! Fantastic work, can't wait to read more. best of luck, Dean
Lorcan
posted July 14, 2008 08:25 AM
Thanks guys, we've got a lot of development work to do yet but it's being wired up next week and I can't wait to hear it running! I'll try to get some video.
posted July 16, 2008 06:48 PM
Lorc, can you explain the clutch setup?
also, what size rear tire is that? :P
Lorcan
posted July 16, 2008 11:41 PM
It's a dry slider clutch and a 14" tyre. The clutch doesn't need to be big like a fuel bike because we have something the fuel bikes don't have - boost control
Ken 12R
posted July 21, 2008 03:57 PM
I cant wait to see this at Santa Pod.
www.uklandspeedracingassociation.co.uk
TRNorBRN6001
posted July 21, 2008 04:11 PM
You guys across the pond are crazy!!!!! I still like your old GPZ750 though.
TFA 200MPH CLUB MEMBER!
harryzx-12
posted July 23, 2008 03:34 PM
That's a bad ass motorcycle. I would love to see it run.
