BIKELAND > FORUMS > DRAGBIKE ZONE.com > Thread: Whew!! thought i'd run outa things to fukup - NOT! NEW TOPIC NEW POLL POST REPLY
posted May 11, 2008 03:56 PM
Yep, I have broken or fukked up just about every part on my heap
Somewhat learning from my mistakes, i was getting resigned to boring turnkey builds.
This morning my new build started right up, sounded great. How boring, I thought. No challenges...
BUT! Lo and behold! Saved from boredom! Woo-HOO!!!
A lil stream of oil was coming from the L. rear of the motor.
Turns out i didn't have the oil seal on the output shaft seated correctly. 20 min later all was well.
tcchin
posted May 11, 2008 05:44 PM
How did you correct that in 20 minutes??
posted May 11, 2008 06:00 PM
if it involved splitting the cases.... you need to be on a race team!...im sure you have the bolts just about worn out from taking it apart so much now lol
ninja12
posted May 11, 2008 06:18 PM
let me guess, you pulled the sprocket and used a socket or seal driver to fix it.
tcchin
posted May 11, 2008 07:13 PM
I am on a race team, and if it were mine, that bike would have been loaded and covered before I tried to repair the leak. It takes me more than 20 minutes just to clean the old silicone off the case gasket surfaces.
posted May 11, 2008 10:40 PM
Badda-BING!
NOX
PMRA / TMRC Super Street 4022
posted May 12, 2008 04:51 AM
That was my guess...........
42 Wins
21 Runner-ups
Sponsored by:
Scorpion Helmets
Galfer Braking
AMSOIL
Steve's Speed Shop
Kawasaki Sports Center
Mickey Thompson Tires
Catalyst Racing Composites
Conway Cycle
Syed Leathers
posted May 12, 2008 10:00 AM
When Kawasaki has the Shifter forks on top and the Output shaft on the bottom I took a Dull Chissel and put marks around the edges of the case to hinder the seal from leaving! I had one slip out at VIR at the end of the up hill back straight and put me and the Bike in the air! I had taken a Plug Chop and the engine was off and the turn was at about 80 or so! Nothing like silence while you and the Bike are taking places being the Highest in the sky!
sleeperbusa
posted May 17, 2008 06:17 PM
It ran out of oil.
2008 Hayabusa.
64", stock clutch, stock gears, foot shifting,1441cc, 8.98 at 157mph at 260 pounds. Holdin it down for the big fellas..
2013 ZX14R.....to be continued.
  Ignore this member    Click here to visit SLEEPERBUSA's homepage.
posted May 18, 2008 01:46 AM
It ran out of oil.
bahahahahahahahahahahahaha
nope. I always check new builds for "leaks n' squeaks" during the obligatory 3 heat cycles.
This leak was not subtle...
going to the dyno tomorrow.
BIKELAND > FORUMS > DRAGBIKE ZONE.com > Thread: Whew!! thought i\'d run outa things to fukup - NOT! NEW TOPIC NEW POLL POST REPLY
0.24931907653809 seconds processing time
