BIKELAND > FORUMS > DRAGBIKE ZONE.com > Thread: Harley's on Pinks......LOL NEW TOPIC NEW POLL POST REPLY
NOX
PMRA / TMRC Super Street 4022
posted May 01, 2008 07:29 PM
FYI guys, sandpaper on the clutch plates is not a fix, and just makes things worse......
Bad no no......., just eats up the fibers faster.........
LOL
42 Wins
21 Runner-ups
Sponsored by:
Scorpion Helmets
Galfer Braking
AMSOIL
Steve's Speed Shop
Kawasaki Sports Center
Mickey Thompson Tires
Catalyst Racing Composites
Conway Cycle
Syed Leathers
zrexpilot
posted May 02, 2008 03:43 AM
didnt see it, but I think a sanded steel is better thn a glazed steel, I bead blast my steels all the time. Now I know Harley's are dry clutches, dont think its much different though.
NOX
posted May 02, 2008 04:28 AM
By glazed, do you mean purple? If so, that is heat discoloration........., if the steel is still flat, it hurts nothing..........
Still , its not the proper method. Might get you one or two passes, but its just gonna mess things up........
When I think of glaze, I think of some other substance on top of the surface....., ie, glazed donut......lol.
42 Wins
21 Runner-ups
Sponsored by:
Scorpion Helmets
Galfer Braking
AMSOIL
Steve's Speed Shop
Conway Cycle
Syed Leathers
posted May 03, 2008 06:48 AM
I hear ya NOX...I saw that episode, they make fools of themselves...
I think they should bring back Jason Miller and Mike Slowe on updated Turbo's for another Pinks Grudge Race!!!...That was the best bike show on pinks ever!!!
NOX
posted May 03, 2008 07:29 AM
Yes, it was a good one.......
I was just cracking up at the whole clutch sand paper thing.........
Some old tricks are old for a reason.........
If it was the better way to go, we would all have BD mouse sanders hooked up at the races!
42 Wins
21 Runner-ups
Sponsored by:
Scorpion Helmets
Galfer Braking
AMSOIL
Steve's Speed Shop
Conway Cycle
Syed Leathers
zrexpilot
posted May 03, 2008 09:51 AM
By glazed I mean polished and blue, that comes from slippage. On a wet clutch plate there are dimples in the steels do you know what those are for ?
explain why sanding the steels is no good.
NOX
posted May 03, 2008 10:43 AM
Color hurts nothing unless they are warped........
Sanding eats the fibers up.........
But if you want to keep doing it, go ahead, they will keep selling you plates............
If sanding the steels was a good thing......, pro teams would be doing it all day long.........
Its a temporary fix, not a solution. You should not be having to take a clutch pack out all the freakin time and work on it.........
Pro teams take them out every pass for another reason..........
42 Wins
21 Runner-ups
Sponsored by:
Scorpion Helmets
Galfer Braking
AMSOIL
Steve's Speed Shop
Conway Cycle
Syed Leathers
zrexpilot
posted May 03, 2008 11:01 AM
that color is from heat and causes hot spots, (raised pimples) on the plates, those raised areas must be sanded off and then the plates are bead blasted, and whalla, you have a good as new steel again. Bead blasting gives more surface area for oil to cling to. Just like the dimples that are already there, bead blasting just adds more.
Nothing you can do about a warped steel, its trash.
How do you know what pro teams do ?
You dont have to take your clutch out everytime because you aint making no power. The people that do make power look at the clutch pack after every pass.
tshultz
posted May 04, 2008 04:38 PM
I was told that sanding the color off the steels won't hurt. unless their warped then there junk. But i have a bead blaster that i use and so far have no troubles.
woppî
posted May 04, 2008 11:39 PM
@NOX
pm sent
thanks
woppi
aliveagain
posted May 05, 2008 04:19 AM
I was concerned after bead blasting my steels about residual blast media not washing out and creating havoc on the bearings.Hot soapy water and all but just don't know about the dimples.
NOX
posted May 05, 2008 05:20 AM
Color on the steels wont hurt, it is not a film, its just color......., unless they are warped........
42 Wins
21 Runner-ups
Sponsored by:
Scorpion Helmets
Galfer Braking
AMSOIL
Steve's Speed Shop
Conway Cycle
Syed Leathers
ninja12
posted May 05, 2008 12:57 PM
What do you use to clean the packing grease off new steels?
zrexpilot
posted May 05, 2008 01:20 PM
solvent
posted May 05, 2008 02:17 PM
you dont have to according to one of doug meyers old posts
NOX
posted May 05, 2008 03:45 PM
What are these "new steels" ? I have the "2002 steels"...........lol
42 Wins
21 Runner-ups
Sponsored by:
Scorpion Helmets
Galfer Braking
AMSOIL
Steve's Speed Shop
Conway Cycle
Syed Leathers
BIKELAND > FORUMS > DRAGBIKE ZONE.com > Thread: Harley\'s on Pinks......LOL NEW TOPIC NEW POLL POST REPLY
0.27381801605225 seconds processing time
