BIKELAND > FORUMS > DRAGBIKE ZONE.com > Thread: R & D MOTORSPORTS dose FANTASTIC WORK NEW TOPIC NEW POLL POST REPLY
zx12mark
posted April 11, 2008 08:16 PM
i waited to post and now i must tell you guys my transmission is awsum.
mark at r&d was able to referb almost every part that had wear which was`nt many.i had never split engine case`s before but if you can swap valve shims on a zx12 you can get those transmission shafts out to send to mark if yours are fucked.i replaced my timing chain and thermostat while i was at it.i also adjusted the valves and sync the throttle bodies. i guess i had about 45 hours into the whole job.r&d`s bill was around 750.00.i had a ron ayers bill of parts for around 200.00 unrelated to r&d`s work.i have been fucked to tears by stealer-ships in my life.
NOT ONE OF THOSE MOTHERFUCKERS WOULD DO THIS JOB AS GOOD AS I DID IT.a stealer-ship would charge at least 1500.00 for labor alone.so the way i look at it is i got the job done free and got payed 500.00 for doing the work.mark at r&d is a true wizard.please give him your business if your transmission is sick.
NOX
PMRA / TMRC Super Street 4022
posted April 11, 2008 09:08 PM
Ditto that. He is the best.
When I called FBG and asked them about some of the mods they did, they did not do half what Mark does.......
Just having a cut tranny is only half the battle........, he really is that good......., best money you will ever spend......
42 Wins
21 Runner-ups
Sponsored by:
Scorpion Helmets
Galfer Braking
AMSOIL
Steve's Speed Shop
Kawasaki Sports Center
Mickey Thompson Tires
Catalyst Racing Composites
Conway Cycle
Syed Leathers
NOX
posted April 13, 2008 07:41 PM
Found today, that even though the tranny may be great, if you have a cold track, that aint prepped for nothing......, even if you hook like mad out of the hole......,
when you hit third and it spins like hell, it aint gonna shift......, track got bad when the cold and clouds hit, and it dropped me two mph, due to wheel spin......., had to go up on some kill time, and drop quite a bit of pressure to get through the day, and then in the final, you can hear the damn thing spining 4th..., rpms going up and down......., to heck with this cold front.........,
42 Wins
21 Runner-ups
Sponsored by:
Scorpion Helmets
Galfer Braking
AMSOIL
Steve's Speed Shop
Conway Cycle
Syed Leathers
zx12mark
posted April 15, 2008 10:29 PM
thats sucks.
NOX
posted April 15, 2008 10:50 PM
Clutches, I do,
Suspension, just getting the hang of it.......
Works told me my shock is set up wrong.......
But, some of the clutch tune, is unloading the rear when the front sets down in second......, parts on the way from MTC to fix it.....
It was shifting in the quarters, I had the bye in the semi, and in the final, it worked as well, just lost by about 2 ft. The bike was spinning, but it did shift......., thank god......
42 Wins
21 Runner-ups
Sponsored by:
Scorpion Helmets
Galfer Braking
AMSOIL
Steve's Speed Shop
Conway Cycle
Syed Leathers
0.23693299293518 seconds processing time
