woppî
posted February 25, 2008 05:50 AM
ZX12 - rear linkage ?? who knows more ?
should be -- point A lower than poin B ??
could be ---- point A and point B --- horizontal ??
what is the best setup ?? lowering the bike ---- to get a good setup !
i am using a wilbers drag shock ( rear) - stock length
and in front the Lowering Blocks 2 1/4" (schnitz)
please tell me your arguments
thanks
woppi
NOX
PMRA / TMRC Super Street 4022
posted February 25, 2008 05:57 AM
I use adjustable bones, 2.14 blocks in the front, a short works shock, and a link pro.
Main thing is you want a good slow rebound, and no pogo, and as low to the ground as the rules allow. if 2" is the rule, get there. My kickstand is cut off at the little heel peg where you pull it down, that the spring catches on. Only way I could get lower is with a turbo. Brocks header is my lowest point, the linkage, about a 1/4 above that........, Koenig pan, WAY higher than that......
That looks like VH's bike.....
42 Wins
21 Runner-ups
Sponsored by:
Scorpion Helmets
Galfer Braking
AMSOIL
Steve's Speed Shop
Kawasaki Sports Center
Mickey Thompson Tires
Catalyst Racing Composites
Conway Cycle
Syed Leathers
woppi
posted February 25, 2008 08:07 AM
its not my bike ! pic found somewhere ! pic is to show what i mean !
point B is the bolt on the frame --- linkage
i have -- a brocks sidewinder, koenig oil pan, adj. bones, wilbers drag shock - stock length
what i want to know is ?? is it better to mount a short drag shock ? and the point A + B is horizontal ?? is this bad ???
or to use the adj. bones - to lower the bike as much as i can ??
thanks
woppi
1st TFA Member / Austria !
2000 Limited ZX12R NOS
NOX
posted February 25, 2008 01:17 PM
Not sure on that one. I would use what you have, and get it REAL low, tune the shat out of the clutch, and let it rip.
42 Wins
21 Runner-ups
Sponsored by:
Scorpion Helmets
Galfer Braking
AMSOIL
Steve's Speed Shop
Conway Cycle
Syed Leathers
zx12-5807
posted February 25, 2008 05:54 PM
Nox,
Will the link pro give more ground clearance over the stock linkage?
Did the link pro help your 60' much?
2001 ZX12 1287cc
2001 ZX12 1317cc Lee's head
NOX
posted February 25, 2008 06:31 PM
Maybe a hair, and yes.
42 Wins
21 Runner-ups
Sponsored by:
Scorpion Helmets
Galfer Braking
AMSOIL
Steve's Speed Shop
Conway Cycle
Syed Leathers
NOX
posted February 27, 2008 08:13 AM
Get in touch with "LinkPro" over on psycho bike, I cannot post there, but we need him over on this site. He has a lot of info, and can explain things a lot better than I can. He is the one who builds them, and sells them directly to schnitz. Billet Proof Racing is his business name. His real name is Brian. Nice guy to deal with.
42 Wins
21 Runner-ups
Sponsored by:
Scorpion Helmets
Galfer Braking
AMSOIL
Steve's Speed Shop
Conway Cycle
Syed Leathers
