BIKELAND > FORUMS > DRAGBIKE ZONE.com > Thread: powercommander kill NEW TOPIC NEW POLL POST REPLY
ninja12
posted October 23, 2007 08:00 AM
powercommander kill
Has anyone tried to use the PC software as the kill with a AIR shifter?
Any details?.
Texas12R
posted October 24, 2007 04:18 AM
I intend to use the PC hub with a selector switch .....the selector will toggle between a
handle bar switch and the (and/or) hub output.
the software will allow you to give the output qualification ie
output = on when 95 percent tps(and) 10,000 RPM OR.....
output = on when 95 percent tps(or) 10,000 RPM
The actual Kill time is from the quickshifter sensor. It is also software based and can be
set from 65ms to 600ms
Perhaps you could expound on your intensions. It might give some of us insight and new ideas
Michael
ninja12
posted October 24, 2007 07:01 AM
I'm thinking of using an air tank, solinoid, and cyclinder.
wire it so when you pushed the button to shift it operated the air side and activated the
PC shifter wire to perform the kill at the same time.
Texas12R
posted October 24, 2007 10:30 AM
I like that! I think I will try it with an automotive relay using the n.o. contacts as the sensor
input.....
ninja12
posted October 24, 2007 10:59 AM
huh? what are n.o. contacts and why do you need a relay?.
It's my understanding that you can download the kill software from dynojet,
that will allow you to have push button kill, to foot shift at WOT.
I read somewhere that you could use your horn button to activate this.
If that's true the air side should work just fine.
Anyone using the dynojet software?
0.2583019733429 seconds processing time
