BIKELAND > FORUMS > DRAGBIKE ZONE.com > Thread: brakes dragging. how much et/mph lost? NEW TOPIC NEW POLL POST REPLY
posted October 17, 2007 01:12 PM
I noticed that my front brakes were dragging very bad when i had everything up on the stand when i had my rotors off to get drilled. i took the calipers apart and there was a huge build up of brake dust/dirt on the pistons which i believe was holding the pads aginst the rotors (pistons couldnt slide back in enough) . my wheel would barely move when i gave it a big "spin" (about 1/4 turn). with everything back together now the wheel will spin over a few times before it stops . just wondering how much that would have added to my times at the 1/4 mile and how many mph it knocked off. im guessing maybe half a tenth and 2-3mph?
shiphteey
posted October 17, 2007 09:29 PM
I pried my pads off my rotors at Maxton, went from 202.7 to 202.9....but there could have been other variables (like temp changes and wind) between runs.
I would venture at most a 1/10, more likely 1/2 that, but probably reflected in mph....1-2? 2-3 seems within the scope of possibility if it really was that bad.
A.
Gemini Motorcycles
posted October 17, 2007 09:58 PM
my wheel wouldnt spin around a 1/4 turn, now it will do several with the same force. it had to be holding me back some!
posted October 18, 2007 03:07 AM
KZ,
there are some threads on this issue way back, but basically if you have a mostly track bike, simply take apart the calipers and clean everything with scotchbrite till all is shiny, then assemble without the dust seals. Your dragging brakes will magically stop dragging at all.
Ali,
fix your fukken front brake(s)!!!!! they suk!!!!!
NOX
PMRA / TMRC Super Street 4022
posted October 18, 2007 04:56 AM
Did you champher the holes?
42 Wins
21 Runner-ups
Sponsored by:
Scorpion Helmets
Galfer Braking
AMSOIL
Steve's Speed Shop
Kawasaki Sports Center
Mickey Thompson Tires
Catalyst Racing Composites
Conway Cycle
Syed Leathers
posted October 18, 2007 05:21 AM
nope, just cleaned and somewhat polished everything
posted October 18, 2007 06:04 AM
I cleaned them up and the pistons actually go back into the clipers now lol. you should have seen the build up of shit on them. actually, ill show you once i get this camera thing sorted out, i took pics when i took them apart.
osti33
posted October 18, 2007 03:34 PM
Ali,
No doubt!!
NOX
posted October 18, 2007 04:41 PM
champher/ counter sink the holes
42 Wins
21 Runner-ups
Sponsored by:
Scorpion Helmets
Galfer Braking
AMSOIL
Steve's Speed Shop
Conway Cycle
Syed Leathers
posted October 18, 2007 08:16 PM
ok, i have pics of what i did (finally got the cam to work with a different comp)
drilled front, stock rear:
drilled front and rear:
posted October 18, 2007 08:17 PM
dirty parts!
0.2182559967041 seconds processing time
