BIKELAND > FORUMS > DRAGBIKE ZONE.com > Thread: Can I put Wet nos on a stock motor 00zx12 NEW TOPIC NEW POLL POST REPLY
zxhev
posted October 05, 2007 01:25 PM
I was thinking about installing a wet nitrous system on my stock 00 zx12.Nothing to big maybe a 40 or 50 shot.. What would you guys suggest is a safe route to go, as far as building a motor for the wet shot such as a stock bore forged , 1270 corillo rods etc.. I read somewhere the 00 zx12s has forged pistons, can the stock rods handle 300hp?
lonniemac
posted October 05, 2007 08:35 PM
the stock rods are strong enough for that, muzzy has used stock rods in much more power than that in there shootout bikes b4. you can do around 60 hp dry shot with the stock fuel pump, if you get the upgraded pump you can do around 70 hp dry. of coarse you need a propper map. if you go wett well then higher hp is in reach with the stock motor, but the valvetrain is where its going to show you when to stop. if you dont get the head right then you will eventually have a blown motor. timming will have to be adjusted pending amount you spray also.
zxhev
posted October 23, 2007 04:11 PM
Thanks for the info, if the head has to come off to upgrade the valvetrain I am going to go bigger with 1270 or 1287 with a wet shot.
I'm 320 not suited trying to get in the mid 9's I
TRNorBRN6001
posted October 23, 2007 05:44 PM
JohnnyCheese has a 1270 kit and Muzzy stealth system (wet) for a good price.
TFA 200MPH CLUB MEMBER!
posted October 23, 2007 06:26 PM
i thought the 1270 kit was gone? i was interested in it awhile back....
johnnycheese
posted October 23, 2007 06:35 PM
you can do as much as a 170hp wet shot on a 1270.
but you have to do it correctly
jus1975
posted October 23, 2007 07:36 PM
Hey Johnny, what do you have for sell? 1270 and/or stealth kit.
posted October 23, 2007 07:39 PM
im still interested in it too...
woppi
posted October 24, 2007 01:03 AM
yes you can !
my bike has a stock engine !!! stock pistons !! stock rods !! only a little headwork
and a 60hp wet nos system on it !!! colder plugs,bmc race filters, efir, 2 dial nos controller, brocks sidewinder
works verry well !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
1st TFA Member / Austria !
2000 Limited ZX12R NOS
zxhev
posted October 26, 2007 03:41 PM
Nice setup woppi !!!!!
zxhev
posted October 26, 2007 03:55 PM
Johnnycheese with the 170 wet on the 1270 what is the correct way to do it?
Timing, plugs,valve springs, cams,etc?
0.27026200294495 seconds processing time
