BIKELAND > FORUMS > DRAGBIKE ZONE.com > Thread: spraying on 1270/1361 pistons NEW TOPIC NEW POLL POST REPLY
RAC4IT
Bergie
posted July 03, 2002 08:37 AM
Who has experience spraying on a 1270 or 1361? Specifically a dry shot #34 jet or similar (40hp). Just wondering how those pistons (JE?) will hold up with regular use? Anyone have a dyno chart of a 1270 or 1361 spraying?
zx12r4play
Dirty South
posted July 03, 2002 08:49 AM
Damn man when will you leave well enough alone,its like you are reading my mind or sumptin but thats what I was planning on doing this fall (meaning before the Atco race in Sept)plus I cant afford anymore money work, I am looking for a good cheap to good to be true type deal on a used busa
anesthesiac12
posted July 03, 2002 09:12 AM
Your only spraying a 40hp shot....Thats not enough to hurt anything. You may want to look into a higher volume fuel pump though....
madmike
posted July 03, 2002 09:42 AM
I'm almost positive that Bergie, has the High flow fuel pump already.
RAC4IT
Bergie
posted July 03, 2002 01:58 PM
LOL
Mike's right- I have the Muzzys high volume pump already installed. I just picked up my Muzzys lockup clutch and a new chain today. I will be installing those goddies tomorrow. I just hope this lockup will help reduce the amount of clutches I'm going through at an insane rate...
madmike
posted July 03, 2002 02:13 PM
I am still experimenting with my lockup set-up but I had a good friend who has one on his Busa, and he said his best set up so far was 4 stiff springs and 2 stockers with no weight? so I would try the 4 stiff Muzzy springs and 2 stockers, and see how that works for you, I have 3 and 3 right now but I will be playing around with it more over the next few weeks! keep me updated about your set-up and we can help each other with our set up.
Mad Mike
posted July 03, 2002 02:48 PM
Lockup R&D: go boyz, go!!!!!!!!
Hey Bergie & Mike,
keep that R&D pumping on the lockup!!!!!
When you guys have it figured out will be just about the time I have enough green stamps pasted in my book to get one!!!!
kzz1
"Show me whatcha workin with"
posted July 03, 2002 08:06 PM
Yeah, what Entrophy said
ra12r
posted July 05, 2002 03:22 PM
Isn't what you have equal to MTC's snowflake?! I thought these were centrifigal force actuated. So that the pressure past about 8,000 rpms was too much to pull with a clutch cable? I didn't think these were a mulitstage design, controled by springs. I thought these were pressure plate replacement with the added actuator arms.....?!
posted July 05, 2002 09:55 PM
Not true. I still have the Muzzy lockup clutch on my silver 12. I can pull it in at any rpm, and have clutch shifted at redline before just to prove that I could do it. My last run of 9.71, I was using the clutch for every shift.
RAC4IT
Bergie
posted July 05, 2002 10:46 PM
Just installed tonight
Just took these tonight- installed the Muzzys lockup on my pile. Lever feel is the same as it was before although I haven't ridden it yet so I will post more tomorrow.
You can see the actuator arms that will pivot to apply pressure to the stack as RPM increases.
This is what it looks like with the case installed.
Another shot of the lockup itself. Per the instructions and suggestions of others I have not installed any additional weights yet. Going to try it without extra weight first.
I fired up the bike after the install expecting to hear more chatter especially since it's required that you remove the rubber sound damper from the inside of the case cover but to my surprise it wasn't noisy at all...
zx12r4play
Dirty South
posted July 06, 2002 04:26 AM
Nice do you have to do any mods to the farings looks like a nice set-up.
kzz1
posted July 06, 2002 05:08 AM
Nice setup! How much did it cost?
RAC4IT
Bergie
posted July 06, 2002 12:46 PM
lockup
I haven't fitted the fairing yet but I think it can be pushed outward using a spacer of some kind or just trimmed. I will probably just trim mine but I'm not sure yet.
As for cost I bought the lockup through one of my sponsoring vendors that hook me up with pricing (Fast Lane Cycles) and they passed it on to me cost + shipping but list from Muzzys on it is $549 I think. http://www.muzzys.com/MZLC-K12/index.html
posted July 13, 2002 03:59 AM        Edited By: entropy on 13 Jul 2002 09:40
Bergie,
trim the fairing! It takes me minutes to pull the clutch plates because I don't have to jerk the r lower.
Maybe with the lock up you won't have to go into the clutch as often, but somehow it seems you'll be going in often anyway...
PS: I see you painted your 1361 jugs like stock. Better heat dissapation, eh?
posted July 13, 2002 08:40 AM        Edited By: entropy on 14 Jul 2002 03:30
fukken double post...
RAC4IT
Bergie
posted July 19, 2002 11:37 AM
Do you have any photos of your fairing trimmed for the lockup? I'm about to start grinding on mine tonight!
NINJA12
posted July 19, 2002 05:42 PM
Is the Fairing trim job mandatory or just to make it easier to get back in there?
RAC4IT
Bergie
posted July 19, 2002 07:06 PM
It's mandatory for use with the lockup unless you create some type of fairing spacers and get much longer bolts. I just trimmed mine on the grinder, took about 30 minutes. Will post pics tomorrow.
0.25048303604126 seconds processing time
