BIKELAND > FORUMS > DRAGBIKE ZONE.com > Thread: stock plugs, small dry shot ok? NEW TOPIC NEW POLL POST REPLY
posted September 03, 2007 09:38 PM
stock motor zx-12r, muzzy pipe, power commander 3r, K&Ns
I know I should have cr10ek plugs for nitrous, but if i cant get them in time (nobody has them in stock locally) would i be ok running say a 15-20 shot drag racing the 1/4 with the stock cr9ekpa plugs with the timing retarded 2 degrees and running a bit rich?
thx!
tslewisz
posted September 04, 2007 06:15 AM
Yep. Leave the timing as-is, too.
posted September 04, 2007 09:47 AM
as in stock timing or retard it like i said above?
oh, my ignition map is set up as 3 degrees advanced accross the board now, do i just retard it (either back to stock, or a bit further) for just the upper rpm range?
tslewisz
posted September 05, 2007 05:40 AM        Edited By: tslewisz on 5 Sep 2007 06:41
I'd put it back to stock at 100% throttle in the RPM range you'll be spraying.
posted September 05, 2007 05:57 AM
cool, is a 20 shot about the max i would want to put on stock plugs or is a bit more "safe" ?
ryan schnitz
posted September 06, 2007 04:46 AM
40-50 is fine with stock plugs, stock motor, and stock timing with 93 pump or better fuel. Make sure you add fuel via the power commander.
Ry--
posted September 07, 2007 04:15 AM
Thx! the best we get in my area for pump gas is 91 so ill pick up some octane booster or mix in a little race fuel till i get the plugs i need. (actually just ordered a set from you online )
0.21273994445801 seconds processing time
