BIKELAND > FORUMS > DRAGBIKE ZONE.com > Thread: Lock Up Clutch NEW TOPIC NEW POLL POST REPLY
blubyu
posted July 08, 2007 09:04 PM        Edited By: MadMike on 11 Jul 2007 21:32
Lock Up Clutch
At what stage of drag racing would one need a multistage lock up clutch on a ZX-12? Is it horsepower dependent? If so, what range would one be needed? What are the pro's and con's of having one?
posted July 08, 2007 10:49 PM
ney nox!!!!
let's hear about multi's!!!!
Stuart Racing
N.H.R.A . Dragracing.
posted July 09, 2007 06:23 AM
It's not horsepower dependent...You don't have to be a drag racer to want one...I use mine on the street too...just in case someone wants to try me...(for traction control)..With the right setup you can control your rear tire spin....Multi stage just gives you more tuneability(greatly....)Cons.You have to pay attention to your clutch lever,puller,ect. you don't want to be pulling it in at 100 mph(on a Muzzy's)...MTC has a good package...Single or multi stage...
I've been running lockups for years,street and drag strip..They are good peices ....Plate longevity is longer once you get your setup right...JMO...Others will be along with some more info...
Paul.....
posted July 09, 2007 07:54 AM
Muzzy is a lot harder on the Pull shafts on the street than the MTC IMHO. The #1 problem for street is you cannot pull in the clutch lever at any real speed like if you saw an Oil Spot and wanted to coast through it!
I use one because of close to 300HP. I also use mine more like a stock clutch with with a locking device for top end as opposed to a slipper clutch with Multi stages of Friction control
Stuart Racing
posted July 09, 2007 09:23 AM
Thats exactly what I was worried about before I put a Muzzy in my bike...But mine is setup with a bearing support for the puller shaft that NOX had made for just such an occassion...Plus spring setup is "LIGHT".....and weight on the arms is just right for the top end charge..
If you have never had one , be cautious and ask alot of questions as you are doing....
Do you have a stock motor???
Paul....
posted July 09, 2007 01:12 PM
Paul....
That Bearing is the Main difference between the MC and the Muzzy. If you have the bearing then you are close to the MTC
nox
PMRA / TMRC Super Street 4022
posted July 09, 2007 03:06 PM
The bearing support is a Muzzy copy of the MTC set up.........
the other things done are the special things I did........., and the pull rod made of tool steel.
If you soley ride on the street, I would stay away from it.........,
It elimitates the left hand in drag racing, as you pop the clutch like a bar bike when you launch.............., (if you know how to set it up right), Other wise, you hit your back on the track about even with the tree!!!!!!
42 Wins
21 Runner-ups
Sponsored by:
Scorpion Helmets
Galfer Braking
AMSOIL
Steve's Speed Shop
Kawasaki Sports Center
Mickey Thompson Tires
Catalyst Racing Composites
Conway Cycle
Syed Leathers
blubyu
posted July 09, 2007 07:14 PM
OK..back to my thread....
NOX, are you saying that with a lock up..there is no more "hit and then slide the clutch"? just full on?
zxboy
posted July 09, 2007 08:59 PM
Yep...If you have it setup right you can throw the clutch lever off the line. I had just 4 light clutch springs in mine..... and depending on how your bikes suspension is set up you could end up with as little as just 3 springs in there. The clutch springs, Called static springs in a lock-up, control the launch out to about 15 to 20 feet depending on your gearing. then the arms and weights start taking over and lock up the clutch. the multi-stage adds a set of over ride springs to the arms to delay the lock up further down the track which really helps if you don't have wheelie bars. If you get one you should only change one thing at a time and keep detailed notes...it's easy to lose your setup. I'm sure Nox will chime in here soon. Roy
zxboy
posted July 09, 2007 09:02 PM
P.S. don't screw around with the Muzzy......just get the MTC !!!
nox
posted July 10, 2007 05:07 AM
Roy covered it pretty good.
42 Wins
21 Runner-ups
Sponsored by:
Scorpion Helmets
Galfer Braking
AMSOIL
Steve's Speed Shop
Conway Cycle
Syed Leathers
BlackMagic14
posted July 11, 2007 12:16 AM
How difficult are they to setup? Would it be easier to pasy someone to do it or does it take a lot of TnT and little changes
nox
posted July 11, 2007 05:02 AM
It takes time, but it is worth it...........
Get an MTC, whether you get a single or multi stage........
What they call a single, really has two stages........
I would start with a single stage, they are easy to set up.........
42 Wins
21 Runner-ups
Sponsored by:
Scorpion Helmets
Galfer Braking
AMSOIL
Steve's Speed Shop
Conway Cycle
Syed Leathers
DR JOE
posted July 11, 2007 02:31 PM
Nox,
What is your static pressure??
Doc.
nox
posted July 11, 2007 02:49 PM
Sorry Dr. JOE. I don't give out my clutch set up to everyone.
42 Wins
21 Runner-ups
Sponsored by:
Scorpion Helmets
Galfer Braking
AMSOIL
Steve's Speed Shop
Conway Cycle
Syed Leathers
DR JOE
posted July 12, 2007 05:03 AM
No problem...
nox
posted July 12, 2007 02:19 PM
What I use would not work for you anyway.............
No one uses the exact same pressure............
You have to find what works for your set up.
Good luck with it.
I cant wait to get back out, going to try to take mine out on Sat night, and fine tune some more.
Hopefully this DAMN rain will quit.
42 Wins
21 Runner-ups
Sponsored by:
Scorpion Helmets
Galfer Braking
AMSOIL
Steve's Speed Shop
Conway Cycle
Syed Leathers
DR JOE
posted July 12, 2007 08:00 PM
The reason I was asking is to get a base, as I have read on here and other places. That is the one thing with a lock-up is the difference between 2 bikes and riders. That's why I was asking what your base static pressure was. To see if my base was close to your set up, and if I need to go up or down from where I am at.
If you get the chance, come on over to Thunder Valley and race the PMRA race this Saturday night.
Doc.
nox
posted July 13, 2007 05:08 AM
I am testing this Sat, trying to get this thing to run 5.7s in the 1/8 before I put in on thw quarter......
If your set up is not working right, that will tell you what you need to do. I am not really sure why you would need my pressure anyway, if you know what yours is doing wrong, wheelie, bog, wont move, whatever, you change it, and make it better......
Where most folks mess up, is not tuning it to the end, they get it close, and forget it, and then wonder why I go out, and if you did not see me use the lever, you would think I have a full slider..............
Tune the think, go to a test day,and try to make improvements............
If I still had my single stage, I would come to the pmra race, but I gotta get the ;muliti finished........
Besides, you only pay 100 to win in street et.
42 Wins
21 Runner-ups
Sponsored by:
Scorpion Helmets
Galfer Braking
AMSOIL
Steve's Speed Shop
Conway Cycle
Syed Leathers
stuart racing
posted July 13, 2007 06:20 AM
TRUE........I got NOX'S old single and still had to make real subtle changes for ME and MY bike to work right....Keep working at it...You'll get it....
nox
posted July 13, 2007 01:47 PM
And we are same wb, same motor, same weight........., and I told him to launch at the same rpm............, and we were exact same gearing.......
Another thing is Dr. Joe, gear ratio plays a huge deal, if I change sprockets, I change static. I have a lower first gear than stock, so what worked last year, about flipped me over this year...........
Also, the muzzy hat, and mtc hat, have different installed spring heights.........., about 1mm
42 Wins
21 Runner-ups
Sponsored by:
Scorpion Helmets
Galfer Braking
AMSOIL
Steve's Speed Shop
Conway Cycle
Syed Leathers
DR JOE
posted July 13, 2007 02:45 PM
Thanks for the input, like I said just looking to see what someone else is running.
Also the 9.50 class pays $400.00 to win, though that might get you there.
Once again, thanks for the input.
Doc.
nox
posted July 13, 2007 06:09 PM
Well, I would have to slow down 4 tenths.........
thats a lot to be dogging out......
Good luck Sat........
My old trailer will probably be there, does that count?
Last years S/et champ bought it...........
42 Wins
21 Runner-ups
Sponsored by:
Scorpion Helmets
Galfer Braking
AMSOIL
Steve's Speed Shop
Conway Cycle
Syed Leathers
nox
posted July 15, 2007 06:37 AM
I made some progress last night................
Karl, I have some more info, gotta watch vids on the tv to make sure, if you are going to be around today, I may give you a call on my way to Hattiesburg...........
42 Wins
21 Runner-ups
Sponsored by:
Scorpion Helmets
Galfer Braking
AMSOIL
Steve's Speed Shop
Conway Cycle
Syed Leathers
nox
posted July 17, 2007 07:09 PM
I have a video of my quickest pass to date that I just downloaded, but I cant send it in a damn email...............
File must be too big.......
42 Wins
21 Runner-ups
Sponsored by:
Scorpion Helmets
Galfer Braking
AMSOIL
Steve's Speed Shop
Conway Cycle
Syed Leathers
0.27198505401611 seconds processing time
