BIKELAND > FORUMS > DRAGBIKE ZONE.com > Thread: electric valve switch for nitrious NEW TOPIC NEW POLL POST REPLY
bayou boy
posted June 18, 2007 06:26 AM
anybody know where to get this switch, just tired of opening &closeing my nos bottle when i run.
aliveagain
posted June 18, 2007 08:38 AM
if you google remote nitrous valve,you'll find some options.
ninja12
posted June 18, 2007 03:54 PM
ALWAYS Load before you leave home and unload when you return.
rgeorge
posted June 19, 2007 05:38 PM
Sounds to me like you just need to eliminate leaks in your system. That way you can turn the bottle on when you get to the track and leave on it on until you are done for the day.
Use a squirt bottle with soap and water to find the leaks. Also make sure the seal in your solenoid is not leaking.
If you have any AN fittings that give you trouble, use these:
http://www.aircraftspruce.com/catalog/hapages/del37fittings.php
These little seals work like magic.
posted June 19, 2007 11:17 PM
Rob,
thx for the site reference, they seem to have all the fittings needed.
I am new to playing with airlines, fittings, etc.
How are they sized? tube size = 1/8"??? I'm looking at my bottle, regulator, solenoid and there are no tubes, just fitting matching to fitting.
I need a quick course in AN fittings
rgeorge
posted June 20, 2007 12:19 AM
No Problem
AN Specs are for hardlines outside diameter in 1/16ths. For example -3 fittings are used on 3/16 OD hardlines. Flexible stainless overbraid lines can be used in place of hardlines when needed. The flexible lines are made to have the same flow-rate as the hardlines they replace. Therefore the actual line diameter is not referred to when choosing flexible lines.
Typically on motorcycles we use:
-4 from the bottle to solenoid
-3 or -4 from solenoid to distribution block or shower head
-3 from distribution block to nozzles
The WRENCH SIZES used on -4 lines:
9/16" on the female nut (line)
1/2" male (fitting)
on -3 lines:
7/16" nut
3/8" fitting
Hope that helps,
Ill give a more detailed breakdown when I have time.
rgeorge
posted June 20, 2007 12:40 AM        Edited By: rgeorge on 20 Jun 2007 01:53
Sorry, I just realized that you aren't specifically talking about a nitrous system.
Most of what you are looking at are probably not AN fittings. The tapped hole connections in your bottle, regulator and solenoid are pipe threads (NPT).
I prefer to use NPT to AN adapters wherever possible so all my lines are AN.
NPT fittings seal on the threads and need Teflon tape or paste to seal correctly.
AN fittings are a compression seal on a 37 degree flare.
NPT size refers to inside diameter of the pipe that threads into the tapped hole. I would bet that most of your stuff is 1/8" NPT
posted June 20, 2007 01:20 AM
Rob,
Since I have the Muzzy air shifter, it is high pressure and i do use nitrous to power it
Your info above is EXACTLY what i was looking for, both NPT and AN
I owe you are beer! Make that 2 beers.
Can I pay you the beers at the Texas Mile in Oct?? You are coming, eh?
Karl
rgeorge
posted June 21, 2007 08:47 AM
I'll be there if at all possible.
Cant say for sure yet.
0.23324394226074 seconds processing time
