lietoome
posted April 08, 2007 09:06 AM
Best options for extended chain
I've got 4-9 inch extensions on the way. My question is whats the best way to go about attacking the extended chain?
Buy a continuous link? 2 masterlinks and two stock chains? Aftermarket? How many links am I looking at By stretching 8 inches? Tensile strenght? As of right now I have no power adders, but may be juiced in the near future. The bike will be 90% track and a few weekend outtings. 300lbs fully suited. Can't think of any other info to add.
Thanks in advance.
jeff
Halvefast
posted April 08, 2007 05:33 PM
I just put the same ones on my bike, now running 9.50s like it's going to the grocery store.
I stretched to 64" leaves hard 1.50-54 60ft, doesn't try to wheelie at all, no traction problems with my weight.
I put the RK DRZ(DragRace Chain) 530x140 never had to remove any links, just perfect with 17-43
Fought putting extensions on for the longest time, happy I finally gave in.
ECTA Ohio Mile 195.132mph
NOX
PMRA / TMRC Super Street 4022
posted April 08, 2007 05:37 PM
RK DR chain. 500 lbs less tensil strength than the EK DRZ, which is way heavier.......
This chain is hella tough, very little stretch, and can be ordered in any length.
I have been using it for a long time.
42 Wins
21 Runner-ups
Sponsored by:
Scorpion Helmets
Galfer Braking
AMSOIL
Steve's Speed Shop
Kawasaki Sports Center
Mickey Thompson Tires
Catalyst Racing Composites
Conway Cycle
Syed Leathers
posted April 08, 2007 08:04 PM
I personally prefer the Tsubaki Sigma... never an ounce of problem and very little stretch... I only adjusted my rear wheel 1-2 times...
lietoome
posted April 08, 2007 08:06 PM
thanks fellas.
Bently
2012 14r In Blue and no Mods!
posted April 09, 2007 04:18 PM
Can the above mentioned chains run a 1000 to 2000 miles a year on the street as well?
posted April 09, 2007 04:57 PM
Yep the Tsubaki is an O-ring chain...
aliveagain
posted April 10, 2007 01:00 AM
I read an article where they said the chain companies keep claiming higher tensil strength.It's just an advertising gimick.I have yet to see a comparison for weight between different company chains.
NOX
posted April 10, 2007 05:17 AM
look at it this way, Pro Stock bike runs the EK DRZ. I have run it, but it is higher, and heavy. I went to the RK, picked up a little, and did not have to adjust the chain any more.......
I have done 1.31 and 1.32 short times with a slick and bars on a zx12. That will stress any chain, and will break a DID gold plate in a hearbeat...........
They are faster than an o ring, but if you want to ride on the street, get the o ring chain instead.........
The weight difference is obvious between the RK DR and the EK DRZ. The EK Drz has 630 chain width side plates........, the RK has 530 width side plates, both are a 530 chain.
Look at a bike that has one on it, the EK DRZ is huge.
42 Wins
21 Runner-ups
Sponsored by:
Scorpion Helmets
Galfer Braking
AMSOIL
Steve's Speed Shop
Conway Cycle
Syed Leathers
Halvefast
posted April 10, 2007 07:35 AM
quote: RK DR chain. 500 lbs less tensil strength than the EK DRZ, which is way heavier.......
My Bad, you are right . . .it was RK DR530 that I bought, not the DRZ
smokinzx14
posted April 10, 2007 05:24 PM
I have a DRZ on my zx14 and ran my best pass ever with it ( 8.77 ) ... It didn't seem any heavier than my 530zzz chain .......I saw a guy get hit in the head and back with a chain at the drags, i don't see what brand it was but i know one thing i don't want it to happen to me !!!!
NOX
posted April 10, 2007 07:12 PM
The EK DRZ is a great chain, but not needed in our application. IF i was still running bars and a slick, I would use it.
Good pass, kudos to ya.........
42 Wins
21 Runner-ups
Sponsored by:
Scorpion Helmets
Galfer Braking
AMSOIL
Steve's Speed Shop
Conway Cycle
Syed Leathers
lietoome
posted April 19, 2007 09:02 AM
got a EK Quadra X-ring 530zvx2 ---damn its heavy.
