BIKELAND > FORUMS > DRAGBIKE ZONE.com > Thread: down on hp - perhaps there was a reason... NEW TOPIC NEW POLL POST REPLY
posted March 28, 2007 01:19 AM
did a leakdown test this morning and found 50-45-55-70%
3 cyl had exhaust and 1 w/intake hissing like a pissed off cat.
brand newly built head w/ big intakes and busa buckets... grrrrrrrrrrrrrrrrrr
Thanks to TimChin for being persistent about doing the leakdown. good call, Tim!
BUT, no worries.
Andy @ Metric in Houston is getting a mojo head machine this week and will be giving head jobs real soon.
Wideout
posted March 28, 2007 04:09 AM
Good news man.
zrxdean
posted March 28, 2007 05:33 AM
Arrrrgh. What happened? Thought this was the 'low CR' tuneup?
ninja12
posted March 28, 2007 05:53 AM
Did you let the new girls (valves) connect with them big studs(pistons)?
Check your clearances, Maybe the new valves are seating in an getting tight.
posted March 28, 2007 06:16 AM
The VTP was close on intake (.041) but plenty of clearance on exhaust(.090), and the exhaust is where i heard most of the hissing.
And, there is no indication at all of the valves touching the pistons (girls making foreplay with the studs).
yep, this is the lo CR motor, but Noonan has help on the way, and i should be back to 15.4+ on the next build.
He is taking .020" outa the pockets and piling it on the crown for more margin.
The the valves started leaking????
Maybe bad from the git-go??
aliveagain
posted March 28, 2007 07:58 AM
when is the last time you checked the valve guides?
posted March 28, 2007 08:39 AM
brand new guides, brand new seats, brand new valves, or so i was told
posted March 28, 2007 09:34 AM
ummmm are you supposed to do this?
Y2KZX12R
CompetitionCNC.com
posted March 28, 2007 11:11 AM
Karl, ask who did your valve job if they vacuum tested the valve sealing? If the seats are cut on a machine that isnt SUPER ridgid you can get chatter while cutting. This chatter causes a scalloped effect and will cause a very poor seat seal. This would be spotted instantly with a vacuum checker.
Or, possably the valves got bent while checking the valve to piston clearance? That nice checking tool has a lot of leverage which can be a double edge sword. Thats why i was saying to use 1 finger on the lever for checking. the tool i use is about 8" long and i use 1 finger. After several times with one finger you get the feal for repeatability and can get consistant results.
Another possability like pete said is guides. But if there all new then all should be cool there.
I would vacuum check the valves and then check the valves for concentricity and wobble.
Also check the stem to guide clearance.
Y2KZX12R
CompetitionCNC.com
posted March 28, 2007 01:16 PM
Jim,
thanks for the tips!!
I really doubt it is related to the VTP measurements because i only did that on #1 int and exhaust valves.
My plan is to take the head to Andy and have him "fix it", I'm not sending it anywhere no mo!
The chatter is an interesting thought, and we ought to be able to see it, eh?
anyway, i am just glad that i did the leak down and found the issue.
Thanks again
Karl
NOX
PMRA / TMRC Super Street 4022
posted March 28, 2007 02:17 PM
I love it when Karl has problems, keeps me from wanting to go BIG.............,
Good luck Karl, we all wish you the best.........
42 Wins
21 Runner-ups
Sponsored by:
Scorpion Helmets
Galfer Braking
AMSOIL
Steve's Speed Shop
Kawasaki Sports Center
Mickey Thompson Tires
Catalyst Racing Composites
Conway Cycle
Syed Leathers
posted March 28, 2007 02:21 PM
I dont think tweaked valves would have lived through the Texas Mile weekend. well not in my motor anyway with the luck I have... LOL..
Wideout
posted March 28, 2007 02:37 PM
I was disturbed why you had lost hp prior to the Mile...so I'm just glad you're on to something (thanks to Tim).
osti33
posted March 28, 2007 03:23 PM
BUT, no worries.
EEK!! That sucks man. Glad you found something. Keep us posted on the new head.
TRNorBRN6001
posted March 28, 2007 03:25 PM
Sabotage I Say !!!!!!
Those Garage Barbies just can't keep their hands off your engine!
TFA 200MPH CLUB MEMBER!
ninja12
posted March 29, 2007 07:55 AM
what did the clearances look like?
posted March 29, 2007 08:12 AM
G,
i will CLOSELY look for VTP and piston head interference tomorrow.
on 1st inspection, it SEEMS that VTP is OK, no apparent contact; but that some pistons MIGHT have been tapping (slightly) the head.
I wanna take pix of everything with carbon on, then clean it off and look for collision evidence.
The .030" quench I ran on the last build is pretty tight for a stroker, even w/Carrillos...
This is fun stuff.
0.25332903862 seconds processing time
