BIKELAND > FORUMS > DRAGBIKE ZONE.com > Thread: Quickest 1/4 pass? NEW TOPIC NEW POLL POST REPLY
01zx12r
posted May 28, 2002 05:11 PM
Quickest 1/4 pass?
Im just curious, whats the quickest pass that anyone has made on a 12 without a swingarm or wheelie bars?...Mine to date is a 10.15 @ 143.8 with a 1.76 60'. Dont get me wrong I know thats nothing to write home about but wanting to know what the possibilties are with the stock wheelbase...Thanks all
Lovett Racing/Pedigo Performance
8.40 @170
01zx12r
posted May 28, 2002 07:07 PM
another question
Am also curious how much an extended swingarm benefit me? My 60ft's vary quite a bit from the 1.85 to the best of 1.76. My personal goal is to run an 9.?? with the bike and then install a swingarm...I do hopefully at some point want to compete in the local area Streetbike Shootout class..Thanks again...Chris
8.40 @170
krexken
posted May 28, 2002 07:12 PM
My best is a 9.25 at 158 with the help of a 1361 kit. Stock motor best was 9.60 at 147. A few guys here have run in the 9.30s and 40s with stock motors. I'd say they were exceptional riders though, and light! Get the bike as low as you can get it and keep making runs.
ZX12Girl
Adrenaline Junkie
posted May 28, 2002 07:22 PM
Need4Speed was running 9.4's with an arm / stock motor!!!!
I only ran a 9.90 - stock motor / stock swingarm. I started racing the Busa before I got all I could out of the ZX12R.
ZX12Girl
Adrenaline Junkie
posted May 28, 2002 07:25 PM        Edited By: ZX12Girl on 28 May 2002 20:26
Where is MadMike at??? - he was running some good numbers - Stock arm / motor!!!! I think it was around 9.5's...I could be wrong!!!!
And KCadby and RAC41T were running some awesome times as well...
But these guy's are all awesome drag racers!!!!
BA
posted May 28, 2002 08:44 PM        Edited By: BA on 28 May 2002 21:48
Heyyyyyyy, here's a post I like! hehe
how about 9.30 at 150mph? stock arm, stock tire, stock motor. Just the usual HMF pipe, -1T sprocket, K&N's and lowering. (the 140lb rider didn't hurt either) Pump gas!
:-D yer hurtin' my feelin's there honey!! One minute it's "Big Al's the BOMB!!",........the next it's "BA-who?!?!"
heheheh
posted May 29, 2002 12:31 AM
Team Fat Ass "weighs in" at 9.63 @ 145, stock motor, stock arm (755lbs), with a dense cloud of clutch particles swirling in my wake.
the 1361 w/6" arm has gotten me to 9.12 @ 154. 10 more hp + nutec might get me in the 8's; we'll see in a mo or so...
ZRXDean
posted May 29, 2002 06:50 AM
...a dense cloud of clutch particles swirling in my wake...
LOL - nice imagery entropy. I guess a lockup would give you 1-2 mph, and spare your plates some abuse downtrack - ever thought about it?
madmike
posted May 29, 2002 07:29 AM
No 9.5's with the stock arm, that was with my 6" arm, I think the best I ever ran with my stock arm was a 10.02, but I did notice that the more miles I put on the bike the better it ran. and Im TFA guy at 5'10" and 230...
hotrodninja
posted May 29, 2002 07:40 AM
My new 2002 should be quicker. Already turned a 9.608 at 147, stock arm w/ Muzzy, one tooth down on the front, stock map. 800 miles on the odo. As it loosens up it should run better. Of course the air will get worse as summer sets in. I am 6' 1" and weigh 210.
posted May 29, 2002 09:02 AM
ZRXDean -
My clutch destruction is somewhat down since I got the arm and went to 17/51 gearing. I abuse the clutch much less than the ole "snap n' slide" days.
I haven't thought of the lockup mostly because I am too broke pouring cash into the motor, but also because I really don't understand the benefit over the 6 new Muzzy springs I am running now. If i even grow balls big enough to just throw the clutch out and pin it, maybe then I will get a lockup/??
ninjamissile
posted May 29, 2002 09:15 AM        Edited By: ninjamissile on 29 May 2002 10:17
You guys and girl just blow me away. You lot are some very serious speed merchants. I would love to get the times you are getting. Under 10 secs on stock arm and stock engine is seriously fast. I only have a 10.4 to my credit so I have to do some serious practice. I have my bike set up with NOS but refuse to use it until I can get some respectable times. The fastest I have seen a ZX12 go in England was a 9.51 by my friend Lorcan. That has a long arm and some head work done. I know the tracks over here are total shit but even so you guys and girl deserve a big pat on the back. Maybe one day I can break into the nines.
Ninja Missile
ZRXDean
posted May 29, 2002 09:25 AM
With the power that your 1361 produces -and your TFA status your clutch is most likely slipping somewhat at the top end of the track. Lockups allow you to put your OEM springs back in, and have plenty of slippage at the launch, then as your speed (not RPM) increases, the arms on the snowflake are pushed out, preventing slip. Plus you can fine tune the spring tension and arm weight to help your 60 foots, and save your clutch plates. With the money you spend on plates, you might save $ in the long run..
01zx12r
posted May 29, 2002 09:48 AM
Awsome Replys!!!
Thanks to everyone for all the info..We have some VERY fast people in here...Should have said my bike is using the Muzzy Ti system, K&N's, PC3R and is strapped and lowered, and 16-44th comobo...The rear of the bike is in the 2nd hole on the Muzzy links. Does it need to be lower?...Also the sprocket combo im using i think is to agressive, bike always wheelies in 1st and sometimes have to abort run.
8.40 @170
BA
posted May 29, 2002 10:45 AM
Muzzy Links eh
when I had the muzzy links, I drag raced with them on the bottem hole.
Now I'm using Kennedy's links, they're adjustable and I really like them. I can raise it back up no matter where I'm at, and it only takes a few minutes.
At the strip, the bike is about 1-2" off the ground.
...btw, when you feel that front wheel coming up, try 'fanning' the clutch just a hair,..you know, pulling it in just a fraction *more* than whereever it happens to be at. You can stay in the gas, and usually the front end will settle back down. Works for me.
Lorcan
posted May 29, 2002 02:13 PM
tracks
Hey NM you are a big fella so 10.4 is quite respectable. The quickest I got totally stock was 10.1, and 9.9 with a pipe. I'd like to be able to blame the tracks for not running 9.6s, but the truth is I just couldn't keep the front down (no strap at that time).
810cc - 211mph: www.750turbo.com
  Ignore this member    Click here to visit Lorcan's homepage.
posted May 30, 2002 12:14 AM
ZRXDean,
good explanation, sounds logical, and it looks like a lockup should be in my future. not immediate future cause I am tapped out after the motor stuff, but this year fo sho'.
kawachan
posted May 30, 2002 06:47 AM
Okay, I will post my slow ass times!! My best pass is a 9:68, and I have backed it up with a 9:69 and three 9:70's! I have a full Muzzy Ti, strapped, Ignition advancer, 17/48, Bear stacks, and Links in the middle hole. I know there are some low 9:60's or maybe a 9:50 if I ever get my 60's like I want them. Best MPH is 145.89 I think. No PC either.... Now if I put that 6 in arm on, I see some 9:40's for sure!!
RED NINJAS RULE!!
madmike
posted May 30, 2002 07:07 AM
Entropy, I have a lockup on my bike and it is very clean looking. and you can definatly feel it, Im still working on dialing it in but I will keep you updated on my clutch managment and what Im doing with the springs and weight settings...
Mad Mike
posted May 31, 2002 12:58 AM
Thx Mike,
I am definitely interested in yr progress/experience with it, and who knows, maybe I'll get a 3rd person to smash into my po battered, ole Linc and then State Farm will give me some more cash
Cowboy
posted May 31, 2002 10:16 PM
9.01 TONIGHT.So close i can taste it.
frEEk
posted May 31, 2002 11:47 PM
damn cowboy, sorry i missed that. i was hovering on deciding whether to go r not, and then got called fer dinner. u there every friday? what's the start time?
Cowboy
posted June 01, 2002 06:24 AM
They race allmost every Friday and if I'm not racing out of town I'm there.
posted June 01, 2002 06:25 AM
Damn! Nice! I'll be at Bremerton on Sunday!
dwb
posted June 03, 2002 07:19 PM
I just started racing this year
Actually I bought my first sport bike in sept. (former harley guy)
So far I've been to the track 5 times this year and started off running 10.8's now I'm running 10.5's and a couple of high 10.4's with 1.8 60' mostly .
I have a 2001 with an akrapovic pipe , k&n's , and a power comander and muzzy lowering links in the back ,I'm lowered 3/4" on the tree in the front and have a strap .
Any pointers would be helpful.I would really like to see the 9's by the end of the year .
canadians put DOOTIE on everything...
0.23560905456543 seconds processing time
