BIKELAND > FORUMS > DRAGBIKE ZONE.com > Thread: 180 vs 190 Shinko NEW TOPIC NEW POLL POST REPLY
burnout
posted February 28, 2007 07:42 AM        Edited By: burnout on 28 Feb 2007 07:44
180 vs 190 Shinko
aside from being lighter, I read on another site that the contact patch for the 180 was larger than the 190. This seems counterintuitive, can anyone confirm? Sounds like a win win if true.
1/8 5.66@129.77
1/4 8.74@159.60
SteddyTeddy
posted February 28, 2007 09:07 AM
On a 6" rim the 190 has a wider contact patch, but not by a whole lot.
posted February 28, 2007 11:45 AM
I run the 190 vs.. the 200...
I would think the 180 is smaller??
burnout
posted February 28, 2007 12:40 PM        Edited By: burnout on 28 Feb 2007 12:42
Yeah me too, I'm not a member of the other site so I couldn't inquire further but here is the text. I guess it was air pressure, rim differences or wear pattern.
"Ninjaboy311
That Shinko is getting the job done for sure. We measured the contact of my 180 yesterday compared to a 190 that was on a Busa and mine was 1/2" more contact patch than his."
2005 Texas Shootout
Street ET Champion"
1/8 5.66@129.77
1/4 8.74@159.60
matt sterbator
Hiding in the bushes
posted February 28, 2007 01:02 PM
I always ran a 180. I figured the rim would stretch the 180 out more than a 190, theoretically flattening it in the process, ie: making the contact patch larger. Plus it was a little lighter and less expensive.
SteddyTeddy
posted March 01, 2007 06:20 AM
I broke out my tape measure last night at the track and checked a few bikes. All running 6" rims and Shinko u-softs. The 190's have about 5.5" of contact while the 180's have 5" of contact. If your not having traction problems, go with the lighter 180. I'm running a 190 right now but mainly because I like the looks of a fatter tire on the back.
burnout
posted March 01, 2007 06:43 AM
Cool, thanks for checking that out.
1/8 5.66@129.77
1/4 8.74@159.60
ninjaboy311
posted March 05, 2007 11:35 AM
I had always run the 190 on my old ZX-12R, basically with no problems.
When I got my ZX-14, I pm'd a few people, including Ricky Gadson, about which gets more contact, and they all said the 180, so I tried it.
I admit, the first few passes I would have to lower the pressure to 8 psi, but as the tire got worn in, I was able to go all the way up to 16-18 psi. Then it lasted 200 passes, which I have never been able to do before.
Like someone quoted me earlier, I did measure my 180 on the ZX-14 rim against the 190 on a BUSA rim and I had 1/2 inch more contact.
My bike is sitting at 69" and the 180 is doing its job, PERIOD!!!
I really don't think the 180 is lighter. I think I recall where the 180 was actually a little heavier.
Let's not forget, the 180 is a 55 profile, whereas the 190 is a 50 profile.
It's all about what the rider wants. If you want a fatter look, get the 190. They both hook great regardless of anything else.
Seth ZX12r UK
posted March 05, 2007 07:32 PM
Or as Mike says the 200 section..
  Ignore this member    Click here to visit Seth ZX12r UK's homepage.
blue max
posted March 07, 2007 02:20 PM
i bought a shinko, was advertised as a u-soft but when i got it ,it does not say u-soft on the tag, it reads roo3 and has the tread pattern that the u-soft has, did i get the correct tire?
best 9.23
SteddyTeddy
posted March 07, 2007 08:10 PM
It should be stamped U-Soft on the sidewall. The pattern is the same as the STD 003.
Nelson Taylor
posted March 07, 2007 09:03 PM
I was told that running the 180 will help mph also more than the 190.
Any truth to that?
Best #'s
1.54
4.03
6.02 @ 121mph
(Stock Wheelbase) 2006 ZX14
blue max
posted March 08, 2007 05:50 AM
mine says stealth roo3rr
best 9.23
nightmare
ACP Racing
posted March 12, 2007 06:45 PM
I heard the 180 is a lighter tire as well. I am running a 200 right now but will be going down to a 190. or maybe even a 180 ASAP!
2006 ZX14 Ninja "SWINE FLU"
60ft 1.23
8th Mile 5.16
ACP Racing
SteddyTeddy
posted March 13, 2007 05:00 AM        Edited By: SteddyTeddy on 13 Mar 2007 06:02
Any truth to that?
Only if it's a lighter tire or if the overall diameter is slightly different from one to another. That would change you final gearing some. Since you on a ZX14, the rear wheel weighs nearly 40lbs. Cut some of that spinning weight off and your MPH will increase.
0.35018801689148 seconds processing time
