BIKELAND > FORUMS > DRAGBIKE ZONE.com > Thread: Anyone running a Muzzy C02 air shifter on a 12? I have a question. NEW TOPIC NEW POLL POST REPLY
osti33
posted October 13, 2006 05:01 PM
When hooking up the two wires from the digi-kill one goes to the power comander and one goes to the injector harness. My question is what wire do you pull from the power commander and from which side of the wiring harness? Male pin side or female pin side?
Thanks.
aliveagain
posted October 14, 2006 06:17 PM
Mine is attached to the black wire,second one in,top row next to the unlocking tab.The opposing pin is also pulled and the return wire from the digi-kill was connected there.Nothing says you couldn't just cut either wire and wire in series.The opposing wire was a white with red stripe.Hope this helps,nobody else answered so I went out and pulled my tank.
osti33
posted October 14, 2006 06:29 PM
AA, thanks for the help. I sent you a PM also.
0.24550819396973 seconds processing time
