BIKELAND > FORUMS > DRAGBIKE ZONE.com > Thread: check this out NEW TOPIC NEW POLL POST REPLY
NOX
PMRA / TMRC Super Street 4022
posted October 02, 2006 10:19 PM        Edited By: MadMike on 2 Oct 2006 23:50
check this out
anyone with a single stage lock up thinkin what I am thinkin........., scroll down......
http://ganncustomspeed.com/parts.html
42 Wins
21 Runner-ups
Sponsored by:
Scorpion Helmets
Galfer Braking
AMSOIL
Steve's Speed Shop
Kawasaki Sports Center
Mickey Thompson Tires
Catalyst Racing Composites
Conway Cycle
Syed Leathers
posted October 02, 2006 10:53 PM
hmmmm.... now that looks interesting... finding the correct spring pressure is going to be the trick...
NOX
posted October 03, 2006 05:14 AM
Yeah, but it could be worth the try..............
If you already have a good combo, this could be good, especially if your father in law has a machine shop 5 miles from the house......
42 Wins
21 Runner-ups
Sponsored by:
Scorpion Helmets
Galfer Braking
AMSOIL
Steve's Speed Shop
Conway Cycle
Syed Leathers
posted October 03, 2006 03:08 PM
OK I'm deft when it comes to lock up clutches...
anyone want to splain how they work, pro's con's, streetable?
or have a good link to info...
NOX
posted October 03, 2006 07:30 PM
pros, very consistent, when tuned right, you just whack the throttle wide open, and let the clutch go...........
not streetable really..........
a must for high hp, but can be used on stock motors if you know what you are doing.......
you can also launch off a two step just like a pro stock bike with no bars if you really know how to tune one...........
42 Wins
21 Runner-ups
Sponsored by:
Scorpion Helmets
Galfer Braking
AMSOIL
Steve's Speed Shop
Conway Cycle
Syed Leathers
ZXLNT
posted October 03, 2006 10:19 PM
Dubious a lock-up is a centrifugal clutch, or at least part ways. There are arms that swing out when spun, these press on the pressure plate adding additional pressure to the clutch pack. Most arms you can adjust the weight and therefor the pressure. With high horsepower bikes even with extra stiff springs you'll slip the clutch. With a lock-up it does just that. Locks the clutch up tight keeping it from slipping.
posted October 04, 2006 02:38 AM
so the only way you can shift at high rpm is with an air shifter then?
NOX
posted October 04, 2006 04:59 AM
not unless you want to break the puller rod...........
42 Wins
21 Runner-ups
Sponsored by:
Scorpion Helmets
Galfer Braking
AMSOIL
Steve's Speed Shop
Conway Cycle
Syed Leathers
kcadby
posted October 04, 2006 05:39 PM
You can "clutchless" shift up AND down all you want...
I have over 25K miles on my ZRX turbo on the street (and of coarse some miles at the track also)...
They add pressure as the revs go up, so for "normal street riding" with the RPM only going say??? half way (a bit higher actually) to red-line you can't even tell it's there...
When you rev-high you do need to "clutchless shift" up AND down though...
And as stated above...the lock-up makes it VERY hard to pull the clutch lever in at "high input shaft speeds"...
With 130FtLb torq on pump-gas and 150+ on race-gas (and more boost) I NEED the Lock-up in my STREET BIKE
NOX
posted October 04, 2006 07:25 PM
clutchless down shifts????
never heard of that working without tearing something up.......
42 Wins
21 Runner-ups
Sponsored by:
Scorpion Helmets
Galfer Braking
AMSOIL
Steve's Speed Shop
Conway Cycle
Syed Leathers
posted October 06, 2006 12:01 AM
OK
Thanks guys!
yeah, I never clutchless downshift .....not the bikes anyway :P
0.24657106399536 seconds processing time
