BIKELAND > FORUMS > DRAGBIKE ZONE.com > Thread: white smoke again NEW TOPIC NEW POLL POST REPLY
aliveagain
posted September 14, 2006 12:46 AM
white smoke again
With only 12 passes on the bike,it started smoking white again.My head I just had milled .003 and the cylinder was found true.I'm running just water and water wetter.When I got home,the bike stopped smoking.Other than a warped head,what else would cause the water to get by?
TRNorBRN6001
posted September 14, 2006 05:46 AM
Were ya on the juice? That happened to my bro's Busa, the juice had ate a little hole in the side of the piston and rings. The oil would get burned and white smoke would come out.
Hope it's not that bad for ya though.
TFA 200MPH CLUB MEMBER!
aliveagain
posted September 14, 2006 07:48 AM
no juice.I can smell the water wetter from the exhaust.
TRNorBRN6001
posted September 14, 2006 08:14 AM
That sucks, you might be able to rent it out as a high dollar fog machine. Just kidding ya, hope it's not the head gasket. Wonder what the plugs look like?
ninja12
posted September 14, 2006 11:12 AM
Head gaskets can blow without a warped head.
If you have to go into that engine again, Use coppercoat spray on the head gasket.
I know in a perfect work you should not, BUT when the world is not perfect coppercoat works. Spary both sides and let it dry to a tacky feel before you install head.
BROOKLYNNYZX12
posted September 14, 2006 11:35 AM
If you can smell the water wetter its got a coolant leak inside the motor,head gasket,head bolt...not good news
aliveagain
posted September 14, 2006 11:36 AM
I just talked with my brother who suggested use a coolant leak dye so that when I do an exploratory,I'll know where the leak travel was.Has anyone had any luck using this product?
I used the copper gasket spray on the last gasket and it did the exact same thing its doing now.
Has anyone ever loosened and then retorqued a leaky gasket with any success?
lilmikef
posted September 14, 2006 01:08 PM
Wish I could tell ya, re-torqing the head would work..... but dont think so, do compression check?? maybe seping through cylinder wall.... and or, when you have the head off, check block & head w/straight edge... Good luck, hope you figure it out!!!
Broke ass dragracer!!!
  Ignore this member    Click here to visit lilmikef's homepage.
Y2KZX12R
CompetitionCNC.com
posted September 15, 2006 08:58 AM
Pete, was that head gasket new?
Do you see any leaks externally?
Are you getting any bubbles in the coolant overflow tank?
Did Bill check the top of the block for flatness?
Y2KZX12R
CompetitionCNC.com
aliveagain
posted September 15, 2006 11:49 AM
That was a brand new gasket.Nothing external but I have seen the fluid level drop.Bill checked the cylinder and said it was good.I'm wondering if this was why my cylinder pressure was low.I just got some coolant leak detector dye and was going to put it in tonite.I was hoping to have the bike hold up on Wed.and see if there were any openings left for MIR.
BROOKLYNNYZX12
posted September 15, 2006 11:51 AM
Won't cost anything to re-torque the head!
Orient Express Top Street Bike Winner 8-4-07
aliveagain
posted September 15, 2006 05:34 PM
I hear ya Brooklynnyzx12r, I just dread the thought of traveling any distance only to see it blow smoke after the first run.I also just got my nitrous valves,so I'm nervous about thermal shock..I just want to do it right so not to compound the problem.I'm hoping that there was a scratch on the gasket from installation thats causing it to leak.Running out of time for my license.
posted September 15, 2006 06:56 PM
There are 3 spots available...You have time to get it good Pete!!!
ninja12
posted September 15, 2006 07:11 PM
I've seem the coppercoat tip work more than once.
Could be down and back up in one evening.
Johnnycheese
posted September 16, 2006 03:13 AM
I lost you there.................. you did put the gasket on dry,correct?
and it was a spring steel gasket?
aliveagain
posted September 16, 2006 03:18 AM
Yes,this one went on dry.The gasket before had the copper spray on.
Y2KZX12R
CompetitionCNC.com
posted September 16, 2006 04:23 AM
Its possable those studs dont stretch enough. The head bolts NEED to stretch to keep proper clamping tension on the head gasket. Those studs were quite thick and didnt have any reduced shank anywhere to allow for bolt stretch. Using the stock torque spec for those studs might not me enough torque to stretch the bolts.
Pete, I think you need to crank them down another 10-15 ft lbs more torque to get them to stretch enough for good hot and cold clamping force.
aliveagain
posted September 16, 2006 05:43 AM
I'm about ready to tilt the motor down to pull the head.I'm going to do a few errands and will start on it when I get back.Are you saying I should just retorque the bolts or would you recommend pulling the head?I have a feeling that dye shit isn't going to show anything
BROOKLYNNYZX12
posted September 16, 2006 07:11 AM
I wouldn't bother with the dye,try and fix the leak ,forget about the nitrous and get the bike running for the Grudge Race.You had a good time hangin out last year,it will be more fun racin!
NINJA12
posted September 16, 2006 07:13 AM
Not to jack this thread,
But I really value what Y2k and johnnycheese has to say about engines.
When you say add another 10-15 ft lbs to a torque value I question the value
of a snap-on or other high dollar torque wrench over a $50 craftman.
I've done comparisons with some big name stuff and some budget wenches
and it is usually only 1-2 ft lbs difference at 50 ft lbs. Are these 1-2 critical?
Sorry pete, maybe you can use this info too.
aliveagain
posted September 16, 2006 09:05 AM
Not a problem to learn something new!By the way,I torqued the head to spec plus one flat last time.I will be borrowing my brothers new digital snap-on to torque again.
aliveagain
posted September 16, 2006 12:01 PM
#2 piston missing some metal from the inlet valve relief to the wall.It also looks like the pistons were leaking in between the cylinders on all 3 walls.
BROOKLYNNYZX12
posted September 16, 2006 01:40 PM
You had visible leakage between all the cylinders?
aliveagain
posted September 16, 2006 06:03 PM
I think its leakage.There's a 1/4" black stain between all the cylinders.I have to pull apart the valves on that cylinder to look for damage.The rings are ok,no marks on the cylinder,so it had to have gone out the exhaust.Where can I get another gasket?I believe its a 87mm.Would any machine shop be able to bore it out for me?
My next problem is finding out why it burnt the piston.I haven't even sprayed the dry shot yet.
NINJA12
posted September 16, 2006 09:59 PM
A bad injector maybe? Leaned out.
Only thing I can think of that would melt
one piston without spray.
0.23300886154175 seconds processing time
