BIKELAND > FORUMS > DRAGBIKE ZONE.com > Thread: lockup pains NEW TOPIC NEW POLL POST REPLY
1969ca
posted August 04, 2006 02:12 PM
lockup pains
zx 10 lockup 3 arm no ajustment just weight on arms for high rpm from what i have read and seen at the track is that up decrese the spring rate for slip sence ive put the lockup in my 60ft have sucked went back to stock and they came back i was woundering if you can change youre installed height with washers would this work insatlled height now is 1.146 sping is 1.692 witch give you .546 of crush i have .051 washers to decrease installed height what do you guys think
zxboy
posted August 04, 2006 05:00 PM
Lock ups can be a pain to setup.....not sure if I understand how much weight or springs you have in yours ? First thing you need to do is set it as it came to you out of the box. You also need to find out how much "static" pressure it has. To check the static pressure find someone with a valve spring checker. Set it to the installed height of 1.146" and see how much pressure is on the springs. Add up the pressure from all the springs and thats the "Static pressure" of the lock up. This static pressure controls the first 10 to 20 feet of your launch depending on the gearing. If your aggressive with the clutch you'll want less static pressure. If you want to throw your clutch away at the line you'll want even less....
Don't be afraid to experiment !! If you have 6 springs try just 4...but keep track of the static pressure number so you can see what's helping and whats not. And yes you can shim the springs if you need more pressure.
The arms and weights start controling the clutch 20 feet out.... The less weight the further down the track I'll lockup.... Again don't be afraid to experiment....... Try no weights. I know of some people that have even removed some of the arms.
If the bike wants to do wheelies further down track you'll need to be removing weights.
For example.... I use to run a lock up in my 12 before I went to a slider and I only had three of the six springs in mine with the static pressure being around 130 lbs. (stock spring pressure was around 270 lbs)
Do just one change at a time because you can get lost pretty quick......Hope that helps, Roy
NOX
PMRA / TMRC Super Street 4022
posted August 06, 2006 05:57 PM
test...........
test
test
test
test
test
then repeat......
only change one thing at a time, and clutch temp is also important.........., rpm counts as a change...........
42 Wins
21 Runner-ups
Sponsored by:
Scorpion Helmets
Galfer Braking
AMSOIL
Steve's Speed Shop
Kawasaki Sports Center
Mickey Thompson Tires
Catalyst Racing Composites
Conway Cycle
Syed Leathers
1969ca
posted August 08, 2006 08:07 AM
went to the track on sat night and had 2 of the 6 springs out and it helped frist 2 passes were 1.64 and 1.65 way better than 1.75 and 1.77 last pass of the night went to spray and did a 1.71 60ft but 9.70 at 147 not to bad and then my cluch cover started a leak sorrry gush the whole side of my lower fairing was wet so went home
zxboy
posted August 08, 2006 01:23 PM
Are you using factory gaskets?? If so see if Cometic makes a clutch gasket for your bike. They are better than the factory gaskets in that they can be reused many times over....The stock ones seem like they are good once and tend to leak if used over again.
Give us the low down on how your bike is set up ???
NOX
posted August 08, 2006 02:13 PM
Roy, that is funny, I have taken the cover off of mine at least 30 times this year, probably 40 or so last year, and still on the same gasket, , stock........
I always keep two extra, but usually never need em............., dont over torque em.!!!!!!!!!
How is the slider workin? I did some high 1.3s with no bars, but it was too violent at the time, did some trickery with gear ratio, and found a 1.41 the other night, but that was in OK, and at night.
I got back home in the day heat, and it went to like 1.45s or 1.46...........
I think I need more burnout, on the MCR.............., but damn, i hate to use it up..........., shinko wont work, but oh well..............., 13 finals, in 20 events this year, bracket and heads up aint too shabby............, in and out of state..........
how is the slider, you in the 20s yet?
42 Wins
21 Runner-ups
Sponsored by:
Scorpion Helmets
Galfer Braking
AMSOIL
Steve's Speed Shop
Conway Cycle
Syed Leathers
1969ca
posted August 08, 2006 04:09 PM
1down 6 up 6over lowering links straped fork tubes pushed uo about 1.5 inches dyno numbers are 158 and 199 on spray
zxboy
posted August 08, 2006 04:25 PM        Edited By: zxboy on 8 Aug 2006 17:28
You've had good luck with that gasket I couldn't get them to last at all....maybe My spacer plate isn't really true ?? But like I said I have very good luck with the cometic gasket. The best short time so far is a 1.33 and the best E.T. was a 9.03 but not at the same time. Right now with the hot weather it's doing consistent 1.43. I've got a bunch of stuff I want to try and I'm sure I can do high 1.20's and the eight's are possible, but it's so dam consistent right now I don't want to touch a thing...... I'm tied for 4th, 10 points out of 3rd right now in pro-et
1969ca
posted August 08, 2006 04:31 PM
zxboy is what is your bike do you have a 10 with the stock cover and no spacer never replaced gasket soon as i put the lock up in had sealing problems im going in the shop to check spacer if it is true and if you have the 10 what is your clucth set up and what do you launch at
01zx12r
posted August 08, 2006 06:01 PM
Solution
You guys are prime canidates for data loggers. Watching the engine rpm and pressure plate rpm as well as tire speed Chris
Lovett Racing/Pedigo Performance
8.40 @170
zxboy
posted August 08, 2006 06:30 PM
1969ca, I had the lock up in my zx12. It is a pro-et setup. Slick, wheelie bars, 2-step etc... So my set up would be no good for you. I'm running a slider right now and love it ....
zxboy
posted August 08, 2006 06:38 PM
The lockup spacer is probably not true...I think some one on this site or the 12.org site had a fix...I think they lapped the surface on glass plate and solved their leaking problem.
01zx12r is right we are a prime candidates for a data logger....
NOX
posted August 09, 2006 05:18 AM        Edited By: NOX on 9 Aug 2006 06:20
Wow, I thought I was doing bad in the heat doing 1.45s........
This was Friday night, in OK, at a Outlaw shootout, basically run what you brung........, This was my fastest pass spinning, but did not do too bad, this is a 1.41 short time......., 3000 DA air, spinnin the top as well.................
This is what a lockup should sound like, ......, pretty smooth, and if you look hard, I toss the clutch............, give me a break on the light...........
http://www.youtube.com/watch?v=Xmt8K_nZoKw
It boggs a little out about 60 ft or so, cause it spun a hair and the weights came in a little early..........
42 Wins
21 Runner-ups
Sponsored by:
Scorpion Helmets
Galfer Braking
AMSOIL
Steve's Speed Shop
Conway Cycle
Syed Leathers
zxboy
posted August 10, 2006 06:01 PM        Edited By: zxboy on 10 Aug 2006 19:02
Yes sir, your doing just fine with those short times..... The video looked and sounded good.
I'm starting to like 1/8 mile racing. I've run most of the SEMDRA races and some local 1/8 mile stuff. You got to have your act together and it doesn't give you a lot of time to be looking around for the other guy during a bracket race. I've run as fast as 5.70's @ 120.
P.S. I can't resist but you sure were asleep at the light on that video
NOX
posted August 10, 2006 06:49 PM
My best with bars, back when we were swapping info was 1.31, 3.72, 5.72, at 124, at a 1/8 mile bracket race, in like april, at night............, that was with stock pipe, open header, and no pc........., 16/56 gear, top of 4th in the 1/8th........., track had to be awesome to hold it though, and we ended up backing off that set up, it was too violent, and RRR would not hold it, it would have run 8.9s in the 1/4 like that, if RRR would have held it..........
I do miss doing those 4th gear burnouts.............., I have thought about going to 73 or 75 inches, and a slick, and running the two step, with no bars, but Street Et money is better right now in this area, if pro et money comes back, this thing will look badass with a slick at 70 something inches, I have the same arm as you, but mine is 10 to 16 over...........
I like 1/8 mile too, trick is, dial .01 under what you think it will run, and run it out the back door every pass..........
also, i like it better, cause you can cool down faster between rounds...............
I really dont know what is up with that track, there are always numbers up on the tree....., not sure if that was my light or not, but I had some wheel spin, i would not have been that bad...., but oh well........, everyone can screw up now and then......, i dont have the magic button like you............lol
Glad you are doing well........, call if you need anything................
42 Wins
21 Runner-ups
Sponsored by:
Scorpion Helmets
Galfer Braking
AMSOIL
Steve's Speed Shop
Conway Cycle
Syed Leathers
01zx12r
posted August 12, 2006 07:28 AM
I wasnt cutting anyone down or commenting on ability to tune, I was only making a suggestion. I have actually 2 systems to monitor clutch on my bike and actually will be selling one very soon.
If anyone is interested in a v50 from Racepak let me know
Chris
8.40 @170
NOX
posted August 14, 2006 05:17 AM
How much?
42 Wins
21 Runner-ups
Sponsored by:
Scorpion Helmets
Galfer Braking
AMSOIL
Steve's Speed Shop
Conway Cycle
Syed Leathers
1969ca
posted August 14, 2006 01:17 PM
Ok i dont know how to tune but got to start swome where when you use light springs what would leave at rpm just want to know a good start point im stuck on reving it and sliding the clucth when it had the stock set up in it
NOX
posted August 14, 2006 02:53 PM
Test............., repeat..............
What works for you, will not work for me, and what works for me, will not work for you.........., what works for another guy wont work for anyone else........, HP, total package weight, how you release the clutch, all plays a part in it
there is a small window for the sweet spot, but when you find it, it will hook when no one else will, and be smooth as glass.........
What springs do you have now? What wb are you at? How much weight on the arms?
How much do you weigh, and what RPM do YOU like to leave at, ie, where can you hold it good and smooth, without it jumpin around.........
42 Wins
21 Runner-ups
Sponsored by:
Scorpion Helmets
Galfer Braking
AMSOIL
Steve's Speed Shop
Conway Cycle
Syed Leathers
01zx12r
posted August 17, 2006 04:44 AM
v50
It has 2 rpm signals for clutch, 1 engine and battery voltage. I purchased the live data option so I could verify settings without having record a sesion. It also comes with a remove located record button....$600. azx12rush@aol.com
8.40 @170
NOX
posted August 17, 2006 04:55 AM
So you can verify how much clutch slippage you have, compared to rpm, and wheel speed?
42 Wins
21 Runner-ups
Sponsored by:
Scorpion Helmets
Galfer Braking
AMSOIL
Steve's Speed Shop
Conway Cycle
Syed Leathers
01zx12r
posted August 17, 2006 04:23 PM
Yes, I actually have 2 different data loggers on the bike right now. The DL-32 im now using with do much more than JUST watch slippage of tire and clutch. I no longer need the v50. I watch the speed of the pressure plate, rear wheel and engine rpm with either system. Alot of work hooking up everything and making sensor brackets, pick-up points, etc etc but yes...Works well too. The v50 was bought new for 900 and I added the live view function for another 150. So you can watch clutch speed (v50) or clutch speed as well as air/fuel ratio, tps, up to 32 possible different channels with a DL-32. Chris azx12rush@aol.com
8.40 @170
NOX
posted August 17, 2006 08:14 PM        Edited By: NOX on 17 Aug 2006 21:15
Wish I had the money right now........
but, I am thinking of racing the Div 4 NHRA series next year at 75 inches and a slick.......,( i still have a two step on my bike right now, its just set at 14000 rpm, lol) and data loggers are prohibited......, I will keep it in mind though
42 Wins
21 Runner-ups
Sponsored by:
Scorpion Helmets
Galfer Braking
AMSOIL
Steve's Speed Shop
Conway Cycle
Syed Leathers
0.24382090568542 seconds processing time
