BIKELAND > FORUMS > DRAGBIKE ZONE.com > Thread: wire your starter botton nos on botton NEW TOPIC NEW POLL POST REPLY
1969ca
posted June 27, 2006 01:53 PM
ive been told that you can use your starter button as a nos activation switch how doses this work any help would be great need to know how to wire this
osti33
posted June 27, 2006 02:37 PM        Edited By: osti33 on 27 Jun 2006 15:38
That's how I have mine setup.
I'll have to check my wiring but I'm pretty sure it goes like this...Keep in mind I'm just going off memory here. I don't have my bike in front of me.
Under the right side(when sitting on the bike) ram air cover there is a connector with 5 or 6 wires in it. You cut the blue/white wire coming out of that connector and going towards the FRONT of the bike. Then you just get a toggle switch run one end of the blue/white wire you just cut to the middle pole on the toggle switch. Run the other end of the blue/white wire you just cut to one of the end poles on the toggle switch. Doesn't matter what end. The you run one wire from your NOS solenoid to the other end of the toggle switch. Then the other wire coming out of the solenoid goes to a GOOD ground.
Thats it.
Flip the toggle switch one way hit the starter button and the bike sould start. Flip it the other way and you have nitrous with the starter button.
If the bike doesn't start switch the blue/white wires on the toggle switch. The one in the middle goes to the end and the one on the end goes to the middle.
It's a piece of cake really.
Good luck!!
posted June 27, 2006 07:23 PM
yep, exactly what I did also!!
MM
1969ca
posted June 27, 2006 09:08 PM
hey thanks for the help make sence to me
rac4it
Bergie
posted June 28, 2006 09:55 AM
mm when did you start spraying?
osti33
posted June 28, 2006 12:47 PM
When he couldn't hang with me anymore!! LOL! j/k Mike.
0.2756028175354 seconds processing time
