BIKELAND > FORUMS > DRAGBIKE ZONE.com > Thread: 1272 on 1270 NEW TOPIC NEW POLL POST REPLY
jaws12r
posted June 19, 2006 10:24 PM
1272 on 1270
please bear with my long story/question:
recently i bolt on a muzzys 1270 with muzzys cams(complete with the vsprings,retainers)+studs...after 3000miles a valve sung on the 3rd 1270 pistion..after checking out with muzzy.i order a piston(supose to be 1270) + welded crank to increase to 1375 set up.. yesterday i just discover the piston they send me is different...its the same size as 1270, but its different in length from the other 3 1270 old piston..my bike shop email muzzys they told me muzzys dont sell a 1270 piston,and ive to order 4....
QUESTION : do you think the wiseco 1272 piston will fit in the muzzys 1270cylinder(its in great condition) with my muzzy crank...is it 100% possible for this 1377cc set up.
the muzzys 60mm welded crank is new...other than that i have the muzzys cams,valve springs,retainers,ss valve (new from u guys)stud n nuts..what else i need?
zxlnt
posted June 19, 2006 11:08 PM
Look at my post on pyschobike. If I were to guess, since you ordered a stroker crank you probably got a cut down 1270 piston. When you go with the stroker crank they cut the domes of the 1270 pistons to lower engine compression. If I were to guess that is..
Call them back and double check..
NOX
PMRA / TMRC Super Street 4022
posted June 20, 2006 05:22 AM
sounds like that great customer service from Muzzy's again..........
Nothing against Rob himself, he has always been great with me, but unless it is a have to have item, I will not order anything from them again...........
Their tech advice has cost me more money rounds than I would like to think about...............
42 Wins
21 Runner-ups
Sponsored by:
Scorpion Helmets
Galfer Braking
AMSOIL
Steve's Speed Shop
Kawasaki Sports Center
Mickey Thompson Tires
Catalyst Racing Composites
Conway Cycle
Syed Leathers
Megabyte
posted June 20, 2006 07:31 AM
We(Velasco) used the longer Wiseco pistons on my 1361. Everyone commented that they were quieter than muzzys. Since my 1361 makes 212rwhp, who was I to argue
buddy
posted June 20, 2006 11:08 AM
Ditto to post from NOX.
ninja12
posted June 20, 2006 11:56 AM
Best thing muzzy had was Doug Meyer!
There products are not bad if you don't need any help or have a problem.
The customer service is to hopeless to ever describe.
I would rather have Mikey from OCC answer tech question about muzzy products
than Dave or Kirk at Muzzy's. I can't figure if they dont know or just won't help.
I bet they are related to Rob or has something on him.
Doug is still around on the board, he may step in and advise you.
madmike
posted June 20, 2006 02:29 PM
Hey jaws, email me the photo of the pistons if you can and I can let you know if they are the cut one's or not! also, I do not believe a 1272 piston will fit in a 1270kit??? but I am not 100% on that either.
Megabyte, are your pistons in a Muzzy Block or did you send the block off with the pistons to be bored out?
thanks
MM
Megabyte
posted June 20, 2006 02:36 PM        Edited By: Megabyte on 20 Jun 2006 15:37
My Block was sent out with the pistons.
RAC4IT
Bergie
posted June 20, 2006 06:39 PM
Been there, done that. http://dontbescaredracing.com/photos/misc/pistons/
1270 shown left, 1361 shown right.
Oh and, YOU'RE WELCOME!
jaws12r
posted June 21, 2006 05:47 AM
MM
MM my camera just gave up on me. I am still looking for another Camera so i can post PICs cheers and by the way Great Cam Degree Kit !
lonniemac
posted June 21, 2006 02:44 PM
my dealings with muzzy is that if you originally placed the order through them then they will sell parts on some kits. i have three 1270 pistons from them now that i will be ordering one of soon in order to have a spare block kit ready. i dropped a valve on one of them. i am running big block now. and i tried that with 1272 wiseco pistons in the 1270 hole and it mics out to tight. cant remember the numbers.
jaws12r
posted June 23, 2006 08:53 AM
okie guys here are the pics
this is the older piston which came with my 1270 kit about 6 months back its says JE 984P
This is the NEW piston dat came with my upgrade kit it reads JE 944M
when placed together u can see a slight difference in the place where u insert the rods
there is also a difference in the grooves
Placed side by side there is also a difference in height
but in diameter they are the same the top are not re-machined in any way
HELP ME !
rac4it
Bergie
posted June 23, 2006 09:54 AM
You're screwed.
ninja12
posted June 24, 2006 08:17 AM
Surely you are not the first to blow a 1270, someone has a old style 1270 piston.
Post a wanted ad in the classified.
0.27601099014282 seconds processing time
