BIKELAND > FORUMS > DRAGBIKE ZONE.com > Thread: entropy! ?? for ya.. NEW TOPIC NEW POLL POST REPLY
posted April 14, 2002 09:18 PM
Hey bud, just a couple of questions for you. on your mapping that you had sent to me for your 1361. did you ever try that map I had adjusted for you? and did you run your bike first with the reg, Muzzy Map for the 1361? thanks and let me know I want to try a few things this weekend. in Bristol... thanks man
Mad Mike
posted April 14, 2002 11:56 PM
MM,
I tried the Muzzy map and some variations on it but never tried yr map due to track problems at the time. It seems we had a lot of hi humidity/mist/traction problems on nights when I brought my laptop to do back to back tests and the tests never got accomplished.
I am not satisfied with my map but I need a solid baseline before I change it and I haven't got that baseline yet.
BTW: Bergie's recent experience has me thinking to try a pass with no PC3 but I hate tinkering at the track if I can avoid it.
What are you gonna try at Bristol?
posted April 15, 2002 04:37 AM
well im going to try all of the map's I have, the stocker, your's then the one I adjusted for you, and see what does what, I will have a little more time to do that, I think that map is so rich down low! I noticed yours was 25's and I believe mine are 35's.. but I will let everyone know..
Mad Mike.
posted April 15, 2002 07:49 AM
Mike,
sorry I never followed thru. I got "lost in the sauce" so to speak, i.e. the suspension set, vac pump, bears horns, and ceramic bearings up took all my attention for a couple a months.
Now that I have all that stuff installed, I won't know what did what, but what the hell, I'm having fun!
BTW, I joined IDBA this am, so with some luck I'll be at rRRaceway on May 19th!
madmike
posted April 15, 2002 08:10 AM
awsome there will be two races there this year one on the 19th and one on sept, 8th. should be a good time!
MM
madmike
posted April 15, 2002 01:16 PM
hey bergie, did you have your head done? I rember you were considering it, also Entropy, did you degree your cams? or have anything done on your head? Im just trying to get a baseline of what one should expect? bergie I believe that you have the highest hp that I have seen on the 1361 and with out tuning, wow! I have the high flow pump on mine, and had the valve job done, bear stacks, 1361, and I cleaned the intake up a little to match better. but I have no idea what my F/A mix is doing, I would assume with every thing it is running lean up top, due to the extra air flow that I have going on. I also took my screens out of my ram air intake, I have heard that will allow more air volume in for the ram air? dont know just have to get to the track and test that bad boy out.
Mad Mike
posted April 15, 2002 03:31 PM
MM,
my cams were set at 105/100 and NO headwork was done. Plain vanilla 1361 install. I was thinking that I'd go back into the motor in Oct/Nov, but like Guns n' Roses said: "I got no patience..."
Bergie, definitely takes the cake with his hp, but who knows Mike, maybe you got the king!
Also we gotta find out what Mika did. Even tho 225 sounds too good to be true, he is a serious guy, maybe he did something really good???
posted April 15, 2002 05:31 PM
yes that is COOL, we should all see what mods will get us the most HP.. I think the interstate battery is worth at least 5HP.....
Mad Mike..
posted April 15, 2002 08:06 PM
sounds good man I will get to the dyno soon, I have a race in Bristol TN, this weekend! how far is that from you bergie?? maybe you can make it down this weekend that would be cool! well congrats on the dyno #'s im impressed, I am shooting for 200-205,? but we will see!
Mad Mike
posted April 16, 2002 02:25 AM
WHOA BERGIE!!!! Yr Dyno Rocks!!!
I can't wait to see what you do on the track.
how much do you weigh? (so we can make mph predictions)
BTW, do you have a riveted masterlink? I did have one and my dyno looked wiggly on the top end like yrs. I was told that I had put the masterlink on too tight. Don't know if that's true or not, but when I mounted another chain and took care in the masterlink, my last dyno was smooth.... Go figure
posted April 16, 2002 03:44 AM
WOW! man that looks good!! I cant wait to see your runs!! let us know how you do! this weekend, I will let you guys know which map works the best! man I cant wait to get mine on a dyno. hopefully next week.
RAC4IT
Bergie
posted April 16, 2002 08:10 AM        Edited By: RAC4IT on 16 Apr 2002 20:12
weight
E- I'm down to about 185 pounds now, then add for gear. Bike weighs 525. Used to be just over 200 with gear when I ran my best times but I've been off the bike for a while so it will probably take a couple weeks of practice before you see any decent numbers from me. I did make a couple high nine passes on my friends stock 12 a few weeks ago but prior to that I hadn't drag raced in over a year because of my wreck last March. I'd been to Maxton and that's it. If I were to take a guess- maybe mid to high 9s @ 150 to start this weekend if I can get the launch down. I'm at 100% stock wheelbase right now too.
0.22465801239014 seconds processing time
