BIKELAND > FORUMS > DRAGBIKE ZONE.com > Thread: tank draining hardware: any tips??? NEW TOPIC NEW POLL POST REPLY
posted April 09, 2006 03:22 AM
I'm gonna start experimenting with MRX01 vs U2 vs C-44 and want to put some plumbing on the fuel line to facilitate draining the tank.
Specifically looking for a source of a hi quality valve which can pass gas to the rail or be diverted to a can. Gotta be careful with 40psi gasoline...
any tips???
posted April 09, 2006 07:47 AM
I think think one of these would be cheaper and easier???
http://plumbing.hardwarestore.com/52-302-siphon-pump.aspx
osti33
posted April 09, 2006 08:12 AM
Piece of rubber hose and then suck. Just try to get it out of your mouth before you get a mouth full of gas.
zrexpilot
posted April 09, 2006 08:20 AM
I was thinking of doing that too, but someone told me it wouldnt work. He said the fuel pump wont keep pumping, something to do with the relay. i dont know for sure but I have an easier way. go to academy and buy the siphon bubble or primer bubble or whatever its called, for boat gas tanks. cost 5 bucks and put some clear hose on it so you can see what its doing. It siphons out real well, easy too. I pull the U-4 out then put a little gas back in it with a squirt of Lucas fuel additive, it's like some kind of oil, cleans the injectors too, run it a little bit then park it.
zrxdean
posted April 09, 2006 08:27 AM
I don't see a pressure rating, but these look good Karl;
http://www.racerpartswholesale.com/jiftite.htm
zrxdean
posted April 09, 2006 08:31 AM
Just found it - max 200psi.
posted April 09, 2006 10:18 AM
Dean,
yes indeedy, that's even better than i was thinking; a pair of barb end males, and 1 female, a few feet of fuel line and i'll be in biz. I betcha fuel line isn't that hard to find, just gotta go out and measure the size.
Zrex,
I've done the siphon routine and was too klutzy to get the gas all out. AND the Nutec get destroying the siphon seals. You can jump around the relay, put in a switch. Dr Vince says its easy.
Osti,
A mouth full of VP, hmmmmmmm...
Thanks guys!
posted April 09, 2006 04:01 PM
Karl, if you want OEM fuel like just let me know and I will send you about 2ft of it off of a spare tank I have??
let me know bud!
MM
posted April 10, 2006 01:02 AM
let me know bud!
MM
Mike,
yes indeed! please fedex the gas lines; i'll send back what I don't use
also, could you spare an oil filler cap & o ring; as you know mine took flight...
please send the stuff 2 day delivery; you KNOW i'm good for the cost I wanna change clutch set up and get it back top the track on Fri.
BTW: That Koenig pan is the TITS!!!!
I'll send you the data logs of "that other aftermarket pan" vs the Koenig and i am sure you can find some way to post em, it really, really works!!!!
zxboy
posted April 10, 2006 01:53 PM
Here's what I've been doing......Tip the tank up and install a 4 foot section of hose into the outlet from pump. Put tank back down into normal position and put the hose in a bucket. I've got a plug wired into the pump wiring that by passes the regulator. The plug is the same type that's used in my MPS kill switch..... Plug the teather into the bypass plug and the pump turns on and will drain the tank all the way down. Make sure you stand by while the pumps running so it doesn't cavitate. Takes a little time but works good with out adding extra plumbing.
NOX
PMRA / TMRC Super Street 4022
posted April 10, 2006 01:57 PM
I do the same thing at the end of the year to run pump gas back through......
hey roy, you in the 1.20s yet?
42 Wins
21 Runner-ups
Sponsored by:
Scorpion Helmets
Galfer Braking
AMSOIL
Steve's Speed Shop
Kawasaki Sports Center
Mickey Thompson Tires
Catalyst Racing Composites
Conway Cycle
Syed Leathers
zxboy
posted April 10, 2006 04:53 PM
Hey Nox..... Getting close, went 1.33 with a 9.03 @ 151 at Valdosta running pump gas !!
But my local track sucks and it's back to 1.40's. I'm going to check out the clutch and make some chassis tweaks to try and get the 1.30's back for the next points night.
zxboy
posted April 10, 2006 04:58 PM
I meant to say relay not regulator......
NOX
posted April 10, 2006 05:12 PM
Yeah I had that prob, had to settle for a few hun slow, to make rounds and be dead on consistent.......
I am hoping for some 9.0s when I get out or some 8.9s.......
I think I can get 1.35s..........
I did 1.31 with the single stage and bars......, with the slider, you can do man..........
42 Wins
21 Runner-ups
Sponsored by:
Scorpion Helmets
Galfer Braking
AMSOIL
Steve's Speed Shop
Conway Cycle
Syed Leathers
0.21826004981995 seconds processing time
