BIKELAND > FORUMS > DRAGBIKE ZONE.com > Thread: oil pump question! 2002 zx12r NEW TOPIC NEW POLL POST REPLY
bugnutt
posted February 07, 2006 04:49 PM
when i first got the bike oil pump sucked really quick now i start the bike oil level glass empties after about 7-10 seconds do i need to replace oil pump or just needs to be cleaned dropped pan already and checked to see if screen is clogged screen is clean still does same thingcan any one help before i start replacing and refreshing things that may not need it.
posted February 07, 2006 04:52 PM
I would for sure check the Pickup Screen first...
Oh you can pull the oil pump/water pump out and make sure everything looks good, internally.
bugnutt
posted February 07, 2006 04:54 PM
what else should i look for besides dirt and grime when i remove the pump?
posted February 07, 2006 05:34 PM
leetle metal shavings...
posted February 07, 2006 11:26 PM        Edited By: entropy on 7 Feb 2006 23:31
since you have found a clean pickup screen and presumably you didn't find any, and i mean ANY sparkly stuff in the oil pan, maybe you'd wanna do an oil pressure test. Simply pull off the oil pressure sender and hook up a guage. if you do it, there is plenty of info here about what pressure you should be seeing.
0.21436905860901 seconds processing time
