BIKELAND > FORUMS > DRAGBIKE ZONE.com > Thread: Logging oil pressure w/LM-1: Thx Dean & Doug! NEW TOPIC NEW POLL POST REPLY
posted September 19, 2005 03:20 AM        Edited By: entropy on 19 Sep 2005 04:22
My LM-1 is now logging oil pressure thx primarily to Dean & DougRay; 2 VERY fine gentlemen. Very cool!
with a shim in the relief valve, it is hitting at bit more than 100psi @11k, using Mobil 1 15W50.
Thanks guys!!!! sup: !!!!!!!!!
PS: since you are so helpful, maybe you can tell me why LM-1 Looger just quits sometimes???
Also, now & then the LM-1 just stops recording?????
ninja12
posted September 21, 2005 08:13 AM
Karl,
care to share the details of logging the oil pressure.
Parts, cost, process.
Thanks.
posted September 21, 2005 10:22 AM        Edited By: entropy on 26 Sep 2005 13:08
Ninja12,
not really a big deal:
1. get a 0-100psi MSI WB762 transducer for logging oil pressure (about a $100)
2. get a brass T from home depot so you can run both the MSI and yr stock oil pressure sensor. (about $6)
3. hook the MSI up to 12V pwr and the LM-1 aux box (gnd & MSI 0-5V output)
4. load this table or one like it into Log Works
OilPsi Volt
0 1
100 5.0
5. start logging oil pressure
This isn't perfect but is pretty close
ninja12
posted September 22, 2005 12:11 PM
Thanks,
I like that maybe we can spot a bearing going down before it can do real damage.
zrxdean
posted September 26, 2005 10:51 AM
Glad to help, I'll hopefully try to log for the first time this Wed TNT. Along with boost, fuel pressure, RPM, A/F.
Thanks for the table values
Dean
posted September 26, 2005 12:13 PM
look at em again
I hooked up the sender to a good qual oil pressure gauge, took a buncha measurements and found that the response is linear as hell.
Bottom line:
0 psi = 1 V; 100psi = 5V.
Pretty simple table, eh?
Dean
posted October 25, 2005 06:27 PM
Thanks to a lot of help from Dave Owen, I am seeing everything correctly! A/F, EGT, Duty Cycle, TPS, and Air Box Temp!
Dave was 100%!!
ninja12
posted October 27, 2005 09:32 AM
Ninja12,
Karl, can you post the link to the MSI WB762 transducer?
1197kaw
posted October 27, 2005 10:36 AM
http://www.motorsportsinnovations.com/wb_o2_add_-_in.htm
E.C.T.A. 200 Club
ninja12
posted October 28, 2005 11:31 AM
THANKS!
0.27462196350098 seconds processing time
