BIKELAND > FORUMS > DRAGBIKE ZONE.com > Thread: Air Shifter help NEW TOPIC NEW POLL POST REPLY
blubyu
posted September 10, 2005 07:16 AM
Air Shifter help
I brought a used HP airshifter about 7 months ago, I installed in last week (yeah, call me lazy!!!) It's the schizznit!!! . I want to move some things around to make for better space in my trunk. I'm trying to have the solenoind and regulator setup on the left forward part of my trunk. It's misses out about 1/4-1/2". If I can move the regulator up a little bit, it'll be gravy!!! There are two holes ports, outputs whatever on the solenoid (it is called a solenoid isn't it?) Are both the same output? One of them is plugged. I'd like to remove the plug, use that outlet and plug the former hole. Anyone familiar with this setup..any advice>
Run whatcha brung
Tow whatcha blow
ninja12
posted September 11, 2005 12:40 AM
what happens when you attach a bottle?
If there is regulated pressure you can, but
if i had to guess i'd say not.
0.22580599784851 seconds processing time
