BIKELAND > FORUMS > DRAGBIKE ZONE.com > Thread: adjusting the manual cam tensioner??? NEW TOPIC NEW POLL POST REPLY
posted September 07, 2005 03:00 AM
JC always did that for me, but now I gotta actually learn something.
How are you guys adjusting it??
osti33
posted September 07, 2005 09:58 AM
This is what Jay at APE told me.
"The goal is about 1/4" of slack in the chain between the intake and
exhaust cams."
I personally run the stocker so I have no real input other than that.
posted September 07, 2005 11:18 AM
Karl, I turn the engine Clockwise and with my fingers I turn in the tensioner until it is "SNUG" (as in not as hard as i can turn it by hand, but I feel resistance). I stop right there and and turn the engine a few more times and while turning the engine I check to see if the tensioner is still snug and then tighten the Lock nut
I check it from time to time. The #1 advantage over the Auto Adjustor is the notches in the Auto tensioner sometimes falls in between the notches and leaves the chain loose. The #2 advantage is it cannot back out
rac4it
Bergie
posted September 07, 2005 02:06 PM
Adjust it by feel and noise with the bike running.
posted September 07, 2005 10:40 PM
Thanks, guys.
By some fukken miracle I located my original cam chain tensioner, and now I just gotta decide whether to put it on or adj the maunal one a la tips above.
RA12r
posted September 08, 2005 04:21 AM
I went back to the OEM. Unlike the busa's, we never had a bad design.
osti33
posted September 08, 2005 09:09 AM
No problems with the stock tensioner for me in my stroker motor.
posted September 08, 2005 10:03 AM
Bear Racing had one back out at Gainesville and will never use one again. It made me go to the manual. For street riding, Stock. For racing only Manual
posted September 08, 2005 12:38 PM
well, when I looked closely, my OEM had a broken pin (pivot for that ratchet thing), so i'm staying with the manual for now. Thx on the tip on how to adjust it.
0.22690105438232 seconds processing time
