BIKELAND > FORUMS > DRAGBIKE ZONE.com > Thread: strokers and carrillo? NEW TOPIC NEW POLL POST REPLY
bossman12r
posted July 19, 2005 11:34 AM
Does anyone know at what size stroke a 12 needs block work to make carrillos fit. I know it needs work with a 4mm and up but what about a smaller stroke like a 3mm or 2mm?
gen 4 zx10 is fast
AnotherRedHead
posted July 19, 2005 12:01 PM
i dont think your gonna get a straight answer, i would just put it together and see where it hits. Its easy to fix, just get your alum. bit out
posted July 19, 2005 12:17 PM
you are going to need .040" clear. between the case and the rods "bolts" anyway. Entropy should know!
posted July 19, 2005 02:33 PM
ARH is 110% correct-o!!!
Very easy to fix, a lil bit of grinding aluminum, and a small bit of work on the starter gear. Sounds w-a-y harder than it is, yep!
And, like mike says, just give .040 or so clearance.
bossman12r
posted July 19, 2005 03:35 PM
Ok I just need a 02 crank and stroke it 2mm for the winter project.
gen 4 zx10 is fast
osti33
posted July 19, 2005 03:45 PM
Look here...
http://www.bikeland.org/board/viewthread.php?FID=3&TID=18011&set_time=
bossman12r
posted July 19, 2005 03:47 PM
thanks i asked if one was an 02.
gen 4 zx10 is fast
johnnycheese
posted July 19, 2005 07:13 PM
a0pe has a 4.6 ready to go for an 02
bossman12r
posted July 20, 2005 08:13 AM
JC, I see buddies 4.6 is holding up pretty good under 100 shot.
gen 4 zx10 is fast
AnotherRedHead
posted July 22, 2005 08:30 AM
the size of the stroke isnt gonna be a longevity issue. I would put rods in the bike no matter what. Thats gonna be your weakest link. Make sure a competent builder sets up the tolerances. Just matching numbers to letters to get bearings aint gonna cut it. You need to have your mic's ready for jobs like these.
Nick
0.28441500663757 seconds processing time
