BIKELAND > FORUMS > DRAGBIKE ZONE.com > Thread: here we go again! NEW TOPIC NEW POLL POST REPLY
aliveagain
posted July 12, 2005 04:38 PM
here we go again!
Got the call this morning on the way to a funeral,the bike is making alot of noise.Somehow they fried the jumper wire on the secondary battery for the 24 volt system.I was having them finish hooking up the bottle heater and wanted it on the primary battery.I get there this afternoon to bring it home and it sounded like shit.Freddie thought it might be the cam chain.Once home the bike barely made it up my driveway and sound like its running on one cylinder.I also had to pay for 5 spark plugs due to fouling while syncronizing.He said they might of ran the motor a little lean for awhile.What the f@#k!And all this cost me 777.25.This bike ran strong when I dropped it off.
junior s
posted July 12, 2005 06:07 PM
Your kidding right ?
Get up off your ass and ride !!
posted July 12, 2005 06:26 PM
Dude you have to be joking..... no way I do not charge near enough!!! and my shit runs.....
aliveagain
posted July 12, 2005 06:38 PM
I'm recharging the battery back up now.I pulled all the plugs and they're all wet.I want to wait in the morning to see if that matters.When I put it on the trailor,they had the ground for the blanket on the negative terminal(secondary battery).Trouble is when I have to start the bike,it goes positive.I don't no if this screwed up the ecu or PCIII.I'ld like to find out if I can test the PCIII by plugging it into the computer.I have no compression tester but I'll be draining the oil tomorrow and smell for gas.If it was leaned out enough to go through 5 plugs then my fear is the cylinders are compromised.
posted July 12, 2005 11:11 PM
the ground for the blanket? I dont understand?
psycho1122
posted July 13, 2005 04:40 AM
NOS botttle heater blanket......
On the other S@%T...WTF!!! Good help is hard to find!
aliveagain
posted July 13, 2005 06:22 AM
Checked for fault codes today, none past or present although I can't say any were erased previously.Oil didn't smell of any fuel at least.The motor sounds just like a two cylinder with that deep bass sound and pops occasionally at idle.
johnnycheese
posted July 13, 2005 08:46 AM
check to make sure the coils did not melt
kzz1
"Show me whatcha workin with"
posted July 13, 2005 09:26 AM
sounds internal... better give a compression test and leak down test
aliveagain
posted July 13, 2005 09:35 AM
I pulled the head off and the pistons were wet and carboned but that wiped right off.Cylinders looked ok and no nicks on the pistons or head
chunter
posted July 13, 2005 09:36 AM
they sent you away with a worse running bike?
posted July 13, 2005 12:39 PM
I think we all need to know where this place is so we can avoid it! What did you take your bike to someone else for to begin with?
kzz1
posted July 13, 2005 01:24 PM        Edited By: kzz1 on 13 Jul 2005 14:30
Well... When you pulled the head off you eliminated the compression test and leak down test . That would tell you if there is a ring problem, valves or blown headgasket. Might save you the trouble of taking the head off if the problem is elsewhere? Drain the oil and see if there is any copper particles in there? BTW... Did you check cam timing before you pulled the head off? Compression test would also reveal cam timing off if it jumped a tooth ?
kzz1
posted July 13, 2005 01:26 PM
Eastern Cycle Performance
posted July 13, 2005 02:03 PM
Kzz, you sure named it on what could have caused the problem, Cam timing. It has bitten more than a few People including ??
aliveagain
posted July 13, 2005 02:51 PM
Well,so far I've tested the coils which were a little over the limit,1.2 ohms.Pull the sump,some junk but nonmetalic in the screen,I did find the breather hose folded over on top of a shifter fork.I did find tiny silver bits in the oil when draining out my catch basin.I have no way of testing cam timing,I did mark them this time.The break cleaner fluid messes with my hep c and I had to lay down for an hour and a half.
As far as ECP, I don't want to trash Freddie as I really haven't found whats wrong yet.He called me throughout what was going on and was forthright about problems but didn't want to go further because he didn't do the motor work.
Does anyone have a head gasket for a SBM 1320 block?
kzz1
posted July 13, 2005 03:48 PM
Thats not good.. could be bearing material
Cam timing should have been checked with the valve cover off to make sure the marks on the cam are even with the head and the right pin count is there. You have no way of knowing now if it was off a tooth?
believe it or not, you can re-use the head gasket since you don't have that many miles on the motor
aliveagain
posted July 13, 2005 07:09 PM
Thanx kzz1,I'll have to remember that about the head gasket.As I'll be spraying,I think I'll err on the side of safety and use a new one.
posted July 13, 2005 07:42 PM
Yes use new but you can keep that one in a pinch....
kzz1
posted July 13, 2005 07:52 PM
Still don't know what happened to your bike?
johnnycheese
posted July 14, 2005 05:58 AM
and I have 2 h gaskets in stock as well
aliveagain
posted July 14, 2005 04:34 PM
Split the cases when I got home from work today.This is getting kind of fun now that I went out and bought a couple of used air ratchets.I found a bolt that had backed out and was hitting the clutch basket.The bolt was for the starter motor clutch shaft.While this far I might as well check the bearings.They looked scratched and not polished.Now I was pretty anal about washing out the cases before assembly so either I screwed up or the bolt shavings got in there.Now, if I wanted to close up the tolerance on the rod bearings,doI go with the brown or blue inserts if I have the black inserts now?Also, do I have to replace the rod bolts?I believe the bolts are ARP.
posted July 15, 2005 07:00 AM
YES, The Rod Bolts are Stretch Bolts and as opposed to measuring the Torque, you check the Bolt length when torque to make sure you have the right amount of Squeeze on the Rod. When using plasti Gauge, do the work with the Old Rod Bolts and Nuts. Then once everything is measured, replace the Bolts and use Synthetic Oil to dip the threads in to help avoid the False readings.
Also use a small amount of AntiSeize with a dab of oil on the case bolts to help save the threads!
zrxdean
posted July 15, 2005 07:18 AM
If they are ARP bolts I would reuse them myself. Contact them and see what they suggest. I know Doug has posted that the stock bolts can be reused at least once.
Dean
aliveagain
posted July 16, 2005 02:55 AM
I called Falicon Friday about the bolts.They have plenty in stock but that it is perfectly alright to use them a second time provided they stretch.As I have no way of measuring the stretch,I was just torqueing them an extra 5 ft./lbs.I'll use them again.One of the nice things about the Falicon rods(VH),was they gave me a tube of lube for torquing the bolts.
0.21733498573303 seconds processing time
