dwb
posted April 25, 2005 08:12 AM
zx 10 clutch ?'s
I am new to the zx 10 and I wanted to know if the clutch set up should be changed from stock?
for example. I used to own a zx-12 and was told to take out "spring" plates and to use thicker steels (1.9 instead of 1.6 i think) throughout the stack.Also not to use the small fibers on the inside and out.
Is there anything in the 10 that should be changed like that? Or any other changes like clutch hub or basket.
BTW its a stock motor , stock wheelbase daily rider dragraced every weekednd.
thanx , Patrick
canadians put DOOTIE on everything...
dwb
posted April 26, 2005 08:49 AM
hello , is this thing on ... ?
kcadby
posted April 26, 2005 02:13 PM
For what you are doing???
Stock will work fine...they already have thicker steels than the 12s...
dwb
posted April 26, 2005 02:45 PM
dragracing every weekend
posted April 26, 2005 03:42 PM
Have"nt heard anyone changing the OEM clutch set up!!!
dwb
posted April 26, 2005 03:45 PM
thanx for the input fella's !!
trikchop
posted April 26, 2005 06:43 PM
jist shim the stoch springs and the cluch seems to last fer a good while
