BIKELAND > FORUMS > DRAGBIKE ZONE.com > Thread: PC3R MAP CORRUPTED SOMEHOW NEW TOPIC NEW POLL POST REPLY
RAC4IT
Bergie
posted February 15, 2002 12:12 PM
Has anyone else experienced a condition where the map in your PC3R has been corrupted?
My bike was running like complete ass almost unridable so I finally got around to looking at the map. When I did a 'get all' command it pulled up some rediculous crazy numbers on both the timing and fuel tables!! I mean seriously whacked! Like +22 degrees in somespots or worse! With random timing numbers in every single cell nothing matched or was consistant. The fuel table was just as bad!
I loaded my last known good map back into the bike and everything seems fine now other than it was somewhat hard to start when cold.
I went back 30 minutes later and pulled down the map again and its still fine. But I have no idea what could have caused the map to go crazy like that?
I should have screen captured or saved it so you guys could see how screwed up it was. If it happens again I will do that.
0.27408194541931 seconds processing time
