draggsxr1000
posted February 10, 2005 02:40 PM
rear shock and spring set up.
Hey guys just got my shock back. And i was told to get a 1100 lb spring. Take in consideration i do weight over 300lbs. What kinda preload do i need. I tried none. The bike seemed faster but realy wasnt. Much easier to launch but no improvement in the 60. Any suggestions.
draggsxr1000
posted February 10, 2005 02:41 PM
Bike is a gsxr 1000 with an 9in over arm. Best 60 of 1.62. Bike still wheelied when lauch real hard. But nowhere near as bad.
posted February 10, 2005 04:03 PM
Did you set the sag within the limits written in the manual???
Of course your going to wheelie when you snap the clutch out at redline, your a big dude!!!
What rear tire do you have???...How much pressure and do you get wheel spin???...How long do you do a burnout for???
draggsxr1000
posted February 10, 2005 06:50 PM
Launching at about 5 grand. IM not dumpin the clutch trying to slip some. I have a dunlop 208 with no spin at all. It has never spun. With or without new shock. Just enough to clean and heat the tire. As far as sag goes i have about an inch.
posted February 10, 2005 08:22 PM
Maybe you should put some teeth back on your sprockets then you can leave harder without wheelies...
Dont know what else can be said without seeing how you run!!!
draggsxr1000
posted February 10, 2005 09:29 PM
Yep im gonna try that. I was geared 15 47. That was way to low. But the with crappy shock it helped me. So here we go again. lol aint this so much fun!!!!!!!!!!!!!!!!!!!!!!!
