BIKELAND > FORUMS > DRAGBIKE ZONE.com > Thread: How much juice NEW TOPIC NEW POLL POST REPLY
blubyu
posted November 22, 2004 06:11 PM
How much juice
I'm sorry to repeat the topic if it was up before, however, I gots to know!
Ok..stroker is probably out..as bad as I want it, not sure if it's going to be that much more advantage with the set up I want. A streetable 1270/1290 (is there a difference?) and spray the shit out of it. The question now is, how much spray can you do on a 1270/1290? I read a few times that the 12's bottom end can take 300hp. Of course I would pull some timing out of it with some type of controller. Maybe use the A&J controller to pull timing and add fuel. I'm thinking with a strong 1270/1290 making around 190 and the 100shot, I can get upwards of 280/290 hp. If someone goes by me then..well GodSpeed!!
Am I too optimistic on this? Is this doable, and reliable? Anyone gone this route before? Can't see dropping 4-5K$ on a stroker or 6-8k$ on a turbo. Thoughts, suggestions, anything to help me get through this correctly. Oh by the way, bike has to be a daily driver!
Run whatcha brung
Tow whatcha blow
1bad12r
posted November 22, 2004 10:35 PM        Edited By: 1bad12r on 22 Nov 2004 22:35
This may help. http://www.bikeland.org/board/viewthread.php?FID=13&TID=14548&set_time=
768 Ryderz
0.24734783172607 seconds processing time
