BIKELAND > FORUMS > DRAGBIKE ZONE.com > Thread: Spray on a stk motor ? NEW TOPIC NEW POLL POST REPLY
1bad12r
posted November 04, 2004 04:16 AM
Anybody spraying a stk motor ? If so, what kind of times are you going in tha 1/8 mi ?
768 Ryderz
posted November 04, 2004 05:37 AM
bergie, used to spray the crap out of his stock motor.
I think he ran 8.9's...???
Farmer Rog
posted November 04, 2004 10:24 AM        Edited By: Farmer Rog on 4 Nov 2004 10:26
small shot in 2nd (220# suited) on stock motor. 6.00 at 124, 9.13 @157 at 63in.
Not too many laps with this set-up. I'm sure a 5.8X/8.9X wuz there with more seat-time.
ZX-12R, stock motor, Muzzy/PC3 63in, 60-shot dry, 750#, 9.001
ZX-14, stock motor, Brock smeg/PC3, 63.5in, ~750#, 9.31 NA, 8.95 40-shot dry.
NorthwestDragbike.com
1bad12r
posted November 04, 2004 02:02 PM
Think a stk motor could handle a 50 or60 shot for long with better valve springs ?
768 Ryderz
canadamaxxer
posted November 04, 2004 02:07 PM
Johnnycheese mentioned in the past that the stock exhaust valves are prone to breakage...especially when spraying.
posted November 04, 2004 03:09 PM
I think that's cuz when they roll off at the end of the run, they burp the valves and lose the retainers...Then all hell breaks loose...
johnnycheese
posted November 04, 2004 03:35 PM
nope had them do it without spray
shitty valves nothing more
01zx12r
posted November 04, 2004 04:33 PM
Back when my motor was untouched I spayed a 60hp wet shot running 91 octane unleaded and no timing removed. I ran this combonation for a whole season with a best of 9.03 at 155-157. Tore the motor down at the end of the season. The pistons looked great but the pins were kind of stiff in the piston. Poor lubrication is what I thought but possibly a case of slight detonation.
Lovett Racing/Pedigo Performance
8.40 @170
posted November 04, 2004 05:07 PM
HD springs and Ti retainers will fix that!
your car is slow
Fuck Nitrous...Got Boost?
posted November 04, 2004 05:36 PM
Never had a problem spraying 60 - 75 on a stock motor...provided you can deliver the extra fuel needed to do it!
Do not taunt happy fun ball!
1bad12r
posted November 05, 2004 04:37 AM
Is this very hard to do ? All i want is to run 5's in tha 1/8mi. Ran low 6.30's on stk before. How big of a shot do i need ?
768 Ryderz
rac4it
Bergie
posted November 05, 2004 07:09 AM
#36 jet dry, done.
Although to go 5.9s you will need to hit it right at the 1-2 shift, good luck on stock wheelbase
Farmer Rog
posted November 05, 2004 08:42 AM
What race4it said.......
Even geared down, you're pretty far down track (maybe 250') at the 1-2 shift. Not too much time to make gains on spray.
BTW, at 63in I wasn't able to spray 40 in 1st. Gonna go dual stage next year, with a tiny boost on WOT in 1st, then 2nd stage in 2nd.
keith
posted November 05, 2004 09:06 AM
Dave Schnitz reckons 60 hp max on stock pistons. Not enough meat above the first ring land to run any more, I'd be inclined to take his advice,
cowboy
posted November 05, 2004 11:22 AM        Edited By: cowboy on 5 Nov 2004 11:25
Aftermarket MTC turbo /nitrous have the same amount of meat abouve the first ring land. There just forged instead of cast.I think I got more runs out of stock pistons(before bang) then i did out of stock bore aftermarket pistons with the same nitrous tune up.I don't know why.
If your running just 1/8 mile you should not have a problem.You problem will be getting the nitrous in as much and as soon as possible.
8.87@164 2 stage dry 1290 bore 60hp total
8.89@167 2 stage dry stock bore 80hp total
64 wheelbase
RAC4IT
Bergie
posted November 05, 2004 12:53 PM
@ 63" I was able to grab a #34 pill in 1st right before the 1-2 shift footshifting. Get that clutch out early, as soon as its out on the button = solid 8s.
bossman12r
posted November 05, 2004 03:31 PM
I ran a 70 shoot on my stocker for 2 years
gen 4 zx10 is fast
1bad12r
posted November 05, 2004 06:17 PM
Bergie my bike is 61 inches, and i was wot before the 60FT, AND THE 1st to 2nd shift with my 197hp stroker. I just kept thinking "DBS". Never used Nitrous before , so all this is new to me. Just need a cheap way to keep my #'s on tha track. It left running 5's, I want it in tha 5's when she's back .
768 Ryderz
rac4it
Bergie
posted November 05, 2004 06:46 PM
I always say, pin it til it scares you, then repeat until you get used to it
keith
posted November 06, 2004 09:08 AM
Good idea Bergie
0.27030897140503 seconds processing time
