BIKELAND > FORUMS > DRAGBIKE ZONE.com > Thread: who do the best stroker crank NEW TOPIC NEW POLL POST REPLY
wezze93
posted November 02, 2004 08:58 PM
who do the best stroker weld up crank for the zx12
  Ignore this member    Click here to send wezze93 an AIM message.
Ra12r
posted November 03, 2004 11:17 AM
The best vs correct. There is not a best, but there is a correct way to do a crank. There are several places that do cranks "CORRECTLY". You know the names already........... Falicon, APE, MC......etc
bossman12r
posted November 03, 2004 11:36 AM
What size bore and stroke are you thinking about doing?
gen 4 zx10 is fast
wezze93
posted November 03, 2004 09:29 PM
my bore size is 86mm im thanking about 5mm stroke what size motor would that be?
johnnycheese
posted November 03, 2004 10:46 PM
okay let me fiqure it out
johnnycheese
posted November 03, 2004 11:12 PM
86x60.4=1403
86x60.0=1394
87x60.4=1436
87x60.0=1427
1bad12r
posted November 04, 2004 12:00 AM
I HAD the 1270 with a 5mm stroke, loved tha torque !
768 Ryderz
bossman12r
posted November 04, 2004 04:53 AM
I thought you had the 1375 kit from Muzzy. That had a 4.6 stroke.
gen 4 zx10 is fast
Farmer Rog
posted November 04, 2004 10:29 AM
Bossman, any updates on moving to WA?
check out www.NorthwestDragbike.com if you are.....
ZX-12R, stock motor, Muzzy/PC3 63in, 60-shot dry, 750#, 9.001
ZX-14, stock motor, Brock smeg/PC3, 63.5in, ~750#, 9.31 NA, 8.95 40-shot dry.
bossman12r
posted November 04, 2004 01:50 PM
No, The Army is going back and forth about it. Right now they are telling us we are going between june- aug.
gen 4 zx10 is fast
1bad12r
posted November 04, 2004 01:59 PM
no, i HAD the 5mm.
768 Ryderz
wezze93
posted November 06, 2004 09:22 PM
about how long will a 1403 live with the the good rods on a 100shot wet. an what kind of power an torque should it make on motor with cams, big viles, an head work
1bad12r
posted November 07, 2004 12:28 AM
Dam playa ! You doin it big !
768 Ryderz
bossman12r
posted November 07, 2004 08:07 AM
It should last a long time if there is not oiling problems. HP with spray should be around 315 with 175 Tq
gen 4 zx10 is fast
johnnycheese
posted November 07, 2004 08:20 AM
it won't make close to that and live
bossman12r
posted November 07, 2004 09:01 AM
A 1290 with head work will make 195 and 100 shoot gets it to 295. Big valves and Cams should get you 12hp and stroking it should get you 8hp. That is aroud 215 plus a 100 shoot. 315, right?
gen 4 zx10 is fast
posted November 07, 2004 09:35 AM
100hp dry shot?? Man, that's livin big! Hey Bossman, you gonna be stationed F. Lewis? I go there every so often to work in the communications center there, and am out at McChord AFB about twice as often. Maybe run into ya sometime. Typically, I'm on my ZZR for work commutes, save the 10R for fun stuff.
johnnycheese
posted November 07, 2004 09:41 AM
yes with good headwork and cams it will
storke gives torque more than HP
posted November 07, 2004 09:43 AM
I used to love the torque of my stroker motor. Could lift the front tire up and hold it right off the line at a green light, and never break the speed limit.
superchuck12
posted November 07, 2004 04:30 PM
Hello,my 1403 has stock valves,ported head and larger cams,it made 216 hp,118 lbs/ft of torque.It has falicon knife rods and falicon welded-up the crank,I ran it all season (although not too many passes,77 passes),with 80 horse dry-shot,probably 30 passes on the bottle,tore it down the bearings looked great,the crank looked like new.Hope this helps,Chuck.
ZXLNT
posted November 08, 2004 03:32 AM
What the configuration to get 1403. haven't heard that size before...
johnnycheese
posted November 08, 2004 04:50 AM
86x60.4=1403
86x60.0=1394
87x60.4=1436
87x60.0=1427
right here
bossman12r
posted November 08, 2004 04:52 AM
That is the second time JC, I guess he stroked right pass it the first time.
gen 4 zx10 is fast
wezze93
posted November 08, 2004 08:58 AM
thanks guys my bike spun a bearing because my oil filter came alose an i lost alot of oil so im going to they to make it better my bike made 192 hp on pump gas
Ra12r
posted November 08, 2004 10:50 AM
wezze, mine did the same thing!
0.2584331035614 seconds processing time
