BIKELAND > FORUMS > DRAGBIKE ZONE.com > Thread: what does it take to get in the high 9 sec range NEW TOPIC NEW POLL POST REPLY
draggsxr1000
posted October 17, 2004 07:44 PM
hey what kinda 1/8 mile times does it take to clip into the 9sec bracket. Only three weeks till i find out what i can do. Give me a goal
RAC4IT
Bergie
posted October 18, 2004 04:26 AM
Typically anything quicker than 6.5 should translate to 9s, depends on your ability, weight, gearing and horsepower level.
draggsxr1000
posted October 18, 2004 08:03 PM
6.540 not gonna get me there. hp is 155.7 with a gearing of 15 47 (stock is 17 42) what ya think
RAC4IT
Bergie
posted October 19, 2004 04:56 AM
I said quicker than 6.5
T-REX12R
posted October 19, 2004 08:17 AM        Edited By: T-REX12R on 19 Oct 2004 09:26
how much do you weigh? and are you stock wheel base? Need more info to tell you where the improvement needs to be. Give some numbers on how your runs have been going if you have made any.
MBD Racing
No Excuses!!!
Don't Give Them And
Don't Want to Hear Them!!
9.14@149 on Motor
"05 Tx Shootout Heavy Hitter Champ"
krissten
posted October 19, 2004 08:26 AM
6.55 @ 115mph got me a 9.96 @ 144mph (Stock motor, pipe, PC3, filters, 17/46, stock wheelbase.
I'd say the 6.54 @ 110mph is down in that 9.99 - 10.0 area.
posted October 19, 2004 11:06 AM
Given that you make the same hp as a stock ZX12 but have 85+lbs less weight... it should not be a problem.
matt sterbator
Hiding in the bushes
posted October 19, 2004 11:12 AM
That was me posting.
draggsxr1000
posted October 19, 2004 06:44 PM
well i weight about 300 suited, As far as 1/4 mile runs 0 All have been 1/8th at a very high altitude. With poor track conditions. I am 9in over on wheel base. NOt spinning with 60ft in the low 1.6 range very consistant. t rex here is my personal best.
60 1.620 1.625
330 4.316 4.327
1/8 6.540 6.585
mph 110.210 108.22
the right had side is at the mountain track where traction is limited plus the air is real thin.
rac4it
Bergie
posted October 20, 2004 05:53 AM        Edited By: rac4it on 20 Oct 2004 06:53
9" over, dude... let the clutch out and twist the throttle!
kzz1
"Show me whatcha workin with"
posted October 20, 2004 07:14 AM
Yeah.... What he said
NINJA12
posted October 20, 2004 10:03 AM
60' should be in the mid to low 1.4's with 9" over.
practice, practice and practice. Don't be afraid to try new things.
500 hp won't do you any good if you don't
" ... let the clutch out and twist the throttle! "
draggsxr1000
posted October 20, 2004 12:32 PM
give me some ideas here guys remember i do weigh about 330. If i slip a lil then dump the motor bogs. Slip a lot then a piss pour 60. Any ideas here
T-REX12R
posted October 20, 2004 03:48 PM        Edited By: T-REX12R on 20 Oct 2004 16:51
with you weight I see why you are geared so low.....I am 225 and was geared 15/45 on my 03, 1000...Ihad a 1.49, 60"... 3.997, 330...6.07, 1/8@118.11mph....9.465, 1/4....when I leave the throttle is wide open and I use the clutch. You cannot let the bike get under 9 1/2 grand or it will bog......This method came from alot of trial and error, and it worked for me. Like Ninja12 said..(Practice, Practice, Practice) it can be done. Another ? what year is your 1000 and where do you shift?
MBD Racing
No Excuses!!!
Don't Give Them And
9.14@149 on Motor
RedBull
posted October 20, 2004 04:25 PM
1-800-Jenny-20
I weight about 300 suited, plus the air is real thin.
Call 1 - 800 - JENNY - 20 then go to a sea level track
  Ignore this member    Click here to visit RedBull's homepage.
draggsxr1000
posted October 20, 2004 05:07 PM
You know there is always somone who has gotta say something smart. Anyways i have a 01 model i try to shift as close to the red line as i can.
draggsxr1000
posted October 20, 2004 05:12 PM
I have tried the wide open thing several times. basically thats what im doing but i always get a big wheelie at about the 60ft marker. Right not i launch at around 7 to 8 grand snap out the clutch till the motor begans to bog then slip a lil to avoid that. Im very consistant like this.
T-REX12R
posted October 20, 2004 06:55 PM
work on that 60' as much as posible because itz like me with your weight the bike will only go so fast so the time will have to be cut with a better 60'...If the wheelie is the bigger problem try gearing where I was 15/45 it may let you put a little more hp on the ground .
MBD Racing
No Excuses!!!
Don't Give Them And
9.14@149 on Motor
posted October 20, 2004 08:50 PM
I figured he should twist the throttle to stop and then let the clutch out....lol
rac4it
Bergie
posted October 21, 2004 03:42 AM        Edited By: rac4it on 21 Oct 2004 04:46
You shouldn't be slipping ANYTHING at 9" over. Rev that bitch up more and dump it until it stops bogging or adjust your gearing accordingly. Heavier guys may need significantly more gear than their 200lb friends on the same bike. Let it fly with a leap of faith dude, dont be scared. PS- if you weight that much maybe you should think about trading that 1000 for a Busa or 12. 1000s dont make the torque you need for a good run. Look at the heavyweight hitter class in the MIRockracing.com series, guys going 8.0s over 240 lbs and some guys at your weight going high 8s low low 9s! That's 64" wheelbase (6 over). Put the kit on your 1000 if you dont want to step up to a busa or 12.
rac4it
Bergie
posted October 21, 2004 03:45 AM
ps remember we're not doggin' you we are trying to help you so dont take anything the wrong way! We want you to go 9s!
oof440
posted October 21, 2004 04:27 AM
I am 6'6'' and 400 pounds, I have to be really careful about body positioning when I pull my leg up or the bike will wheelie, usually 60-100 feet out, I have a stock wheelbase 12 and a box stock 10.
T-REX12R
posted October 21, 2004 06:33 AM
I got my 1000 to work well with me but I traded it in and got a 12. Like Rac4it said I needed some more torque. Makes it a bit easier to launch. I put a 1290 kit and now I am Happy. I gear her low too 15/46
MBD Racing
No Excuses!!!
Don't Give Them And
9.14@149 on Motor
draggsxr1000
posted October 22, 2004 07:07 AM
well at the moment i dont have a falicon clutch basket so the dump thing is kinda scary.
NINJA12
posted October 22, 2004 07:33 AM
Get the basket, all the smart 12 guys have them.
If something doesn't work for you try something else.
If you leave the same way everytime you will get the same results.
Like you said yourself " Im very consistant like this". Consistants is great for a Bracket racer and will help you when you try new things, but won't help you go faster. Have you got the supension right. BIG advantages can be had right here.
0.2492401599884 seconds processing time
